zedooo
Post by zedooo on Dec 16, 2012 5:47:02 GMT -5
hahahah leave it like that!
Post by scoottrash1990 on Dec 16, 2012 11:58:59 GMT -5
thanks aeroxbud...it looks really good in the sun....
zedooo...i got some nice weather the past few days so i got a chance to wash it......it will get muddy again...its not just an on road scoot....its all terrain.... :rofl:
Post by scoottrash1990 on Dec 16, 2012 12:07:25 GMT -5
well i think its time to pull the oil pump out and switch to premix....i took the scoot to the gas station about 1 mile away and when i got home there was smoke rolling off the scoot and oil dripping off the scoot.... :panic: ....i think i blew an oil line....i dont think i did any damage to the motor...it was not smoking or dripping oil when i got to the gas station...the smoke is from the oil dripping on the exhaust pipe...what are you guy running for premix?
Post by 90GTVert on Dec 16, 2012 14:01:43 GMT -5
That may be as simple as replacing a hose and bleeding it if you wanted to stay injected.
Most use 32:1 to 50:1 premix. Stay with 32-40:1 with most oils. There are some synthetics that are meant for leaner mix ratios, that's the only way I go 50:1. Make sure whatever you get is suitable for premix. Most oils will say injection and/or premix on the bottle.
Post by scoottrash1990 on Dec 16, 2012 18:59:27 GMT -5
ya i got the feed line off the oil tank and it was dry and cracked...im just going to replace both lines...how do you bleed the system? any ideas on how to get the magneto off without the puller tool?
Post by scoottrash1990 on Dec 18, 2012 20:17:32 GMT -5
i got the oil lines replaced and figured out how to get the oil pump primed...its up and running again... :nana: a pic of the feed line that busted...the line was very hard and would snap if i tried to bend it... i figured while i had the flywheel off for the oil line replacement i would shave some weight off the flywheel....i took it into work and shaved it down in the lathe.......i have not got a chance to see if there is and noticeable difference with the lightened flywheel...i will keep you posted when i get a chance to ride it...
zedooo
Post by zedooo on Dec 19, 2012 5:50:45 GMT -5
you can shave it off more!
Post by scoottrash1990 on Dec 19, 2012 7:19:23 GMT -5
i was not sure what was safe to shave off....i have never shaved one down before...i played it safe with .060 off the sides and .050 off the face...i dident want to cut into the area where the fan sits...
Post by aeroxbud on Dec 20, 2012 5:30:37 GMT -5
Will still notice a difference, i would of thought. Better to be on the safe side. You can always do more later.
Post by scoottrash1990 on Dec 20, 2012 7:33:29 GMT -5
im not buliding a full on race scoot so i was not going crazy with it....i need the scoot to be reliable....i got a chance to get a little test ride in and i can tell a difference...it revs up quicker...im happy with it...
Post by scoottrash1990 on Dec 31, 2012 15:44:55 GMT -5
quick question....with the 21mm DellOrto PHBG carburetor will the stock throttle cable for my scoot work with it or did i need to get a different cable?
Post by 90GTVert on Dec 31, 2012 16:16:48 GMT -5
Stock should work, but may require some modifications. Depends what adapter you use.
Post by scoottrash1990 on Jan 1, 2013 21:36:10 GMT -5
thanks Brent... i put an order in with racing planet yesterday for a few parts....i will post pics and info when they come in...
Post by scoottrash1990 on Jan 18, 2013 15:58:21 GMT -5
this is the boss from my scoot on the left and the one from the polini kit on the right.. this is the face plate that measures 13mm... heres the star washer from the polini kit that also measures 13mm heres a pic of the ramp plate against the starter clutch and the boss from the kit on the crank shaft..as you can see the boss covers the whole splined part of the shaft leaving no room to put the face plate on... posting the pics for racing planet so they can see what im talking about....
Post by aeroxbud on Jan 18, 2013 17:58:35 GMT -5
That is a big difference in size!
