Post by oldgeek on Jan 13, 2015 7:06:36 GMT -5
I think it is the Stage6 exhaust flange angle. Both of my S6 cylinders needed work to mount pipes to. I use rollers for spacers at the engine mounting points and made brackets out of flat bar at the pipe mount brackets. I used aluminum here but the rear broke. Steel is better IMO. Yeah, mine seem to end up at a weird angle, and I have to clock the bracket on the pipe to get it parallel to the mounting bracket, its really strange.
Post by oldgeek on Jan 13, 2015 21:40:05 GMT -5
I installed the step cut head today. Without a head gasket squish was .52mm pretty much all around the cylinder. I thought .52mm might be just a little tight so I used a common copper gasket from a 50cc that I opened up to fit the head, then I annealed it. The torqued squish ended up .73mm and compression went from 120psi to 140psi.
At the same time I also installed the turbokit exhaust. The pipe is just too much for this cylinder. The motor will not rev beyond 5k or 6k. It is interesting to see first hand how much a pipe can affect a build.
Tomorrow I will try the Malossi MHR pipe, if it does not work, I can always go back to the RSII pipe, which is the pipe that I have been running. I forgot to bring the RSII pipe home tonight so I could measure it, so maybe tomorrow I will remember to bring it home.
Post by 90GTVert on Jan 13, 2015 22:18:40 GMT -5
Tried lighter rollers or anything else to see if you can get it to hit?
Post by oldgeek on Jan 14, 2015 6:26:43 GMT -5
Tried lighter rollers or anything else to see if you can get it to hit? No. I didn't even think about trying that. I think I have 4.5G sliders in there now, I have some lighter ones I could try out. Also the exhaust port on the cylinder is not matched at all to this much larger pipe. Will that cause issues just testing?
Post by 2TDave on Jan 14, 2015 6:28:12 GMT -5
^^^That's a good point. My setups all run lighter rollers than others. I was running the 3.8 gram that came with the OR before I tried some sliders. The rollers will be going back in. Others are running 8+ gram rollers. Prior to the OR it was 5 gram. My scoot won't hit the pipe with the heavy stuff.
Post by 90GTVert on Jan 14, 2015 8:22:50 GMT -5
I wouldn't worry about matching ports (within reason) while trying pipes. No sense matching it up to one just to find that you don't like it and then the next pipe possibly can't be made to match well from what was done for the last.
The first time I tried a higher rev pipe I thought the thing was weak till I realized I just wasn't getting RPM where it needed to be. Rich jetting and needle settings can make it even harder for a pipe to hit.
Post by jareeb on Jan 14, 2015 10:07:37 GMT -5
my cheap ebay pipe bolts up to my streetrace cylinder really nicely. i have 4g rollers in mine. if it didn't start out in a high gear it would be faster. but it shoots right up to its powerband (9,000-10,000) and the cvt does its job. maybe you could borrow my pipe to try?
Post by oldgeek on Jan 14, 2015 16:39:59 GMT -5
my cheap ebay pipe bolts up to my streetrace cylinder really nicely. i have 4g rollers in mine. if it didn't start out in a high gear it would be faster. but it shoots right up to its powerband (9,000-10,000) and the cvt does its job. maybe you could borrow my pipe to try? Thanks for the offer bro, but I may just pick up one of those feebay cheapo pipes anyway. So I slapped the Malossi MHR pipe on this morning, and it was a horrible fit! I guess it would fit a Zuma correctly? I did not even bother to start the motor just to see how it sounds. As you can see it hit the tire and stuck way out to the side. While the MHR would not fit this build, I had a good idea of what it might fit on, so I took the MHR to the scooter shop where the 99cc build is, and just as I suspected it fits like a glove! The pipe easily clears the 12" low profile wheel, and looks good to boot! With any luck, I will get the 99cc running by the weekend.
Post by oldgeek on Jan 14, 2015 16:51:03 GMT -5
I also put the RSII pipe back on, after getting it's measurements. I took it for a brief ride because it was so cold. I could tell that it pulled a bit harder with the higher compression head, but that's about all I checkd due to the weather.
Squish and compression are currently at .7mm and 140. I wonder if it would be ok to set the squish to .5mm which would put compression around 160 or so? Before I monkeyed with the durations on this build compression was 170 I think, and I did not have any issues that I know of.
I will get the Technigas RSII dimensions posted later tonight unless I get busy with work.
Post by jareeb on Jan 14, 2015 18:53:45 GMT -5
That ebay pipe performs better than I thought it would have guessed. Its has a few issues im going to fix on it this winter.
Post by oldgeek on Jan 14, 2015 20:23:51 GMT -5
Here we go, the dimensions of the Technigas RSII
Post by 190mech on Jan 14, 2015 20:28:53 GMT -5
I think Ive done this one before,will report soon!
Post by 190mech on Jan 14, 2015 21:14:12 GMT -5
Yep,thats it!Has some strange angles,long and large for a 70,looks right in the ball park for a 90+ though!! 26-126-29.2 .73* 29.2-165-38.5 1.6* 38.5-100-53 4.15* 53-160-87.5 6.15* 87.5-50-105 10* 105-51-105 spacer 105-52-87.5 9.6* 87.5-150-23.7 12.25*
total length 854(without stinger) headpipe 34%(ideal 30-32%) headpipe/diffuser 70.5%(ideal 64-68%)
Post by moofus02 on Jan 14, 2015 21:20:37 GMT -5
I think Ive done this one before,will report soon! Moofus has one. Of coarse he does. Lol! Can you compare yours to his in the pic? This is the TG next r 100cc pipe. Some of the straight sections weren't round from the Bender used so I tried to average them. Header id 24mm 29mm 76mm 29mm 32mm 172mm 32mm 35mm 82mm 35mm 39mm 100mm 62mm 62mm 119mm 89mm 89mm 61mm 89mm 89mm 155mm 23mm 23mm 16mm 23mm (end of cone had short straight section) 20mm 198mm 20mm I didn't pull the silencer off but if you need me to recheck anything or need more info or pics I'd be happy to help. I'll get the pro done this week end The first 3 sections had no taper they just put them togather and filled the gap with weld Thanks I hope this is helpful Brian Read more: 49ccscoot.proboards.com/conversation/22759#ixzz3OlbvzTLKJohn's evaluation of the numbers Yeah!Any steps in a pipe is bad news for performance..The cone angles are super old school(60's)..After the stepped head pipe we have a fairly constant angle of 6.5 degrees for the difuser cone(front),after the spacer(belly) its 12 degrees for the baffle cone(rear),,the short straight section in the baffle at the stinger end is for the fitters to have a place to jam the stingers in! The Yasuni C-16 has the following angles; Head pipe 1.6 deg 1st stage diffuser 4.8 deg 2nd stage diffuser 5.8 deg 3rd stage diffuser 8.8 deg spacer/belly----- 1st stage baffle 5.8 deg 2nd stage baffle 12.7 deg Lots more angles there,but thats what makes a great pipe.. I guess the best low buck improvement for the TG Nextr 100cc would be to hack the headpipe off and work to make the transitions smoother..Dont know if its worth the effort though.. I think a C-16 would make a great 100cc Mina pipe,,Ive never tried it,but the dimensions look like it would.. See Ya, John Read more: 49ccscoot.proboards.com/conversation/22759#ixzz3OlcGrs6ISent from my SPH-L720 using proboards Sent from my SPH-L720 using proboards
Post by oldgeek on Jan 14, 2015 22:12:29 GMT -5
I think I will go ahead and try the MHR pipe on the 99cc motor, since it will not fit on the 70cc motor. I would feel safer with the RSII pipe on the 99cc since John thinks it should match well, but doing that would leave me with nothing to fit the 70cc motor except the turbokit pipe which may end up being difficult to get into tune. Either way it looks like I will be swapping pipes around for while.
