Post by Lucass2T on Nov 4, 2015 5:38:46 GMT -5
It seems you can lower the ex port a little to get more ex area. Oh and about those port durations being off..i've heard that before. Especially with iron cylinders. With this one the ports don't look bad, but the durations are off. You might wanna (or let an engine builder do it) get the durations the same.
I've seen some horrible shaped ports where airpockets sat on the edges and just all traces of quick and cheap fabrication.
Post by oldgeek on Nov 4, 2015 6:47:40 GMT -5
It seems you can lower the ex port a little to get more ex area. Oh and about those port durations being off..i've heard that before. Especially with iron cylinders. With this one the ports don't look bad, but the durations are off. You might wanna (or let an engine builder do it) get the durations the same. I've seen some horrible shaped ports where airpockets sat on the edges and just all traces of quick and cheap fabrication. The quality sure seems to be lower on this kit compared to my first one. I just slapped it on as is. I don't even know what the durations ended up being, likely around 134 and 195. It seems willing to rev, but I have been taking it easy so far, the weather is krappy anyway.
Post by Corrosion on Nov 4, 2015 8:40:44 GMT -5
I see you up sized to a 47mm. What, Piston did you end up using? And what pipe are you running?
Post by iwiketuddlz on Nov 4, 2015 8:42:29 GMT -5
Lighten up your rollers..!!!! Worth a shot anyway.... My 2cent
Post by oldgeek on Nov 4, 2015 9:36:51 GMT -5
I see you up sized to a 47mm. What, Piston did you end up using? And what pipe are you running? I used the piston from a 70cc autotech kit. The .003 gauge pulls out a tad easier than is does with the stage6 piston which is stamped 46.95 I am running the MHR pipe, again
Post by oldgeek on Nov 4, 2015 9:41:28 GMT -5
Lighten up your rollers..!!!! Worth a shot anyway.... My 2cent It will rev, I just wont let it for now Going to try not to kill this one so fast.
Post by iwiketuddlz on Nov 4, 2015 11:12:05 GMT -5
Lighten up your rollers..!!!! Worth a shot anyway.... My 2cent It will rev, I just wont let it for now Going to try not to kill this one so fast. Ha I hear ya man... Well in that case don't take advice from me!!!! I tend to burn them up rather quickly lmao Damn expensive race cylinder
Post by Corrosion on Nov 4, 2015 14:57:05 GMT -5
Is that the Team MHR pipe #M3212799. .003 Is what I shoot for on that kit.
That pipe was a little too much for me & my MHR kit. I went with the C-16. It was, a loud SOB too. If it is how the hell you gonna break it in on that pipe? On the MHR it did not make power till 9500. I had eveybody with a set of Ears complaining with that pipe!
Post by oldgeek on Nov 4, 2015 21:13:56 GMT -5
I am not sure which pipe I have MHR team Replica? I will have to check, but yeah it is loud as yell!
As far as the break in period, you know my current method! ::rolleyes:: Maybe it will work this time? Lol
Post by tsimi on Nov 4, 2015 21:38:08 GMT -5
- Warm up Scooter up to 100-110F before every drive. - Keep rpms around or lower then 6000 for the next 300 miles. - Try to avoid hills. Do all this and you should be fine. Now tell me who would do such procedure? Besides me of course.
Post by spaz12 on Nov 5, 2015 0:58:08 GMT -5
I am not sure which pipe I have MHR team Replica? I will have to check, but yeah it is loud as yell! As far as the break in period, you know my current method! :rolleyes: Maybe it will work this time? Lol Drive it like ya stole it?
Post by oldgeek on Nov 5, 2015 5:30:53 GMT -5
I am not sure which pipe I have MHR team Replica? I will have to check, but yeah it is loud as yell! As far as the break in period, you know my current method! :rolleyes: Maybe it will work this time? Lol Drive it like ya stole it? Yeah pretty much! I make a few easy, short passes trying to make sure the carb tune is good enough, and there is no crazy heating, or strange noises. If all seems ok I let it rip WOT for a few short passes, check the temps and repeat.
Post by spaz12 on Nov 5, 2015 13:41:29 GMT -5
Me too. Not a lot of people agree with this method, but I'll keep using it until a motor blows up on me.
Post by iwiketuddlz on Nov 5, 2015 14:18:35 GMT -5
Break in? ? Not sure I know the term....more like start let er warm up then RIP.!!!!!! Till she blows or in my case seize a few hyper cylinders that's all!!!!
Post by Lucass2T on Nov 5, 2015 14:20:55 GMT -5
Me too. Not a lot of people agree with this method, but I'll keep using it until a motor blows up on me. exactly!
