Post by 2strokd on Jul 6, 2010 17:00:19 GMT -5
I use heat and tap it off with a rubber mallet.
Post by stepthrutuner on Jul 6, 2010 19:13:55 GMT -5
Or you could heat the gear and aggressively bump the end of the shaft that the gear will have to come off of against a board laying on concrete or asphalt (use inertia).
Post by stepthrutuner on Jul 31, 2010 9:56:03 GMT -5
2002 Derbi Atlantis (Piaggio).... Pri.: 13/48 (3.69); Sec.: 14/46 (3.29). 12.14 overall.
Post by 190mech on Aug 1, 2010 5:59:21 GMT -5
Reg,Ya got a 137/70-12 rear tire,what speed will she cruise at?
Post by stepthrutuner on Aug 1, 2010 12:16:07 GMT -5
Did you mean 130/70? My stock tire is 120/70-12. Are you asking what the difference in circumference and rpms at crusing speed would be?
Ok. I figured it up I think. Circ. of 130 = 60.21"; Circ. of 120 = 58.48". Diff. of 1.73" or 1.73/58.48 = 2.96%. I'd like close to four times that. I really don't want to go much bigger on tire diam. and have to eliminate my little rear fender and have mud slung everywhere down there.
Post by 190mech on Aug 1, 2010 16:10:10 GMT -5
Yea,I meant 130/70,was wanting to figure what your cruise RPM was with Brents calculator..
Post by 2strokd on Aug 2, 2010 12:46:33 GMT -5
That calculator wont work with a cvt trans. You can set that cvt up sixteen ways to Sunday and get all sorts of mixed results. Not to mention what an over-range would do???
Post by 90GTVert on Aug 2, 2010 13:03:21 GMT -5
The calc kinda sorta works for it. I take the final drive ratio and known RPM and tinker till I get my real world speed/RPM then stick diff tire diameters in there. I wish I could make it more CVT friendly, but it's kinda tricky as you pointed out. You'd need a tach on your clutch bell or something. lol
Post by shakerdriver on Aug 19, 2010 13:06:05 GMT -5
hey guys i've got a 12.9ish:1 final gear with 130/90-10 tire. i'm just trying to get a little more speed out of it, right now it tops out about 32-34 with my 360lbs. frame on it. if i change the gear set to a 9:1 maybe, would that help me with my top speed? i should mention i'm riding an Aprilia rally 50 with a minarelli engine.
Post by stepthrutuner on Aug 19, 2010 14:17:55 GMT -5
hey guys i've got a 12.9ish:1 final gear with 130/90-10 tire. i'm just trying to get a little more speed out of it, right now it tops out about 32-34 with my 360lbs. frame on it. if i change the gear set to a 9:1 maybe, would that help me with my top speed? i should mention i'm riding an Aprilia rally 50 with a minarelli engine. I could not recommend that you change your stock gearing 30% toward less pulling power. Hills would kill your little scooter with that drastic of a gearing change. I think you would be better off tuning/modifying the motor for more torque and/or power and doing a little tranny tuning to make yourself a 40 mph machine. Edit: There is not a lot of difference between the cost of a gearing change and the cost of a good but lower end big bore kit and they are not that hard to install either.
Post by 90GTVert on Aug 19, 2010 14:33:47 GMT -5
I agree. I beleive power would do more for you right now than gearing. BBK, CVT tuning, then maybe look for a gearing change. If you were 150lbs and it was revved out, it might be a different story.
Post by 2strokd on Aug 22, 2010 17:25:01 GMT -5
PM sent
Post by Thebatman on Nov 20, 2010 13:08:29 GMT -5
hey, what ever happened to this thread? i have 10.5-1 ratio...........
Post by 190mech on Nov 20, 2010 17:38:45 GMT -5
Hey theBatman,Get your engine running strong,tune the CVT,THEN decide if gears are needed..10.5 sounds wonderful for a 70-90cc scoot
Post by Thebatman on Nov 21, 2010 22:16:22 GMT -5
hey 190, thanks for the reply.... someone is buying all parts that i may need and i just wasnt trying to miss out on making a whole package.... well crap, z has a 8.5;1, figured my zx would need/want that also... :twisted:
