Post by pgopmx74820 on Apr 30, 2010 22:44:38 GMT -5
can you just stop using this with out removing all the stuff in the how too?
Post by Fox on Apr 30, 2010 22:48:50 GMT -5
No.
You have to plug off the oil port on the carb and remove the drive gear or the entire pump. Running the pump dry can cause problems with your engine.
Post by 90GTVert on May 1, 2010 0:15:46 GMT -5
It's really not that difficult to do. You can get the drive gear off pretty fast if you choose not to remove the whole pump. Just takes a second to put a vacuum cap on the oil inlet of the carb.
Post by Fox on May 1, 2010 1:53:50 GMT -5
I was able to remove the oil pump without removing the flywheel but I had to bend the outlet nipple on the pump rendering the pump useless but who cares? Once removed I took the gear off the pump and re-installed it in the case to keep debris from blowing into the crank seal area.
Post by pgopmx74820 on May 1, 2010 13:21:00 GMT -5
went to take the oil stuff off but mine looked totally different. here is a link to my pictures of it s1022.photobucket.com/albums/af347/mike3367/scooters/?mediafilter=images.. im hoping all i have to do is take off the rod and put back on the top to seal the motor up and cap off the oil inlet. if so by looking at my pictures i was thinking my motor was the 1E40QMB. but im beginning to think not no. thanks for all your help
Post by 90GTVert on May 1, 2010 16:42:33 GMT -5
That's odd. I did some searching and everyone says they are Yamaha/Minarelli (1E40QMB) clones. That's not the normal oil pump, flywheel, or pickup/stator setup though from what I can see in your pics. The transmission looks like it could be a longcase minarelli with a fancy CVT cover that makes it look different, but it's hard to say for sure. The cylinder looks like it very well may be a 1E40 setup, but once again who knows for sure by just looking? They are supposed to be Taiwanese, so perhaps they put a little time into making it unique? Sadly, unique could be a bad thing when you are looking for parts or info.
Post by drawkward on May 1, 2010 16:44:14 GMT -5
Didn't know you had to remove the oil pump as well. What kind of issues are we talking here?
Post by pgopmx74820 on May 1, 2010 16:49:31 GMT -5
i got a pdf manual of this motor and it say what i pulled out was the whole pump so ill see what happens. i look at the motor and there is no pump under it like your in the how too
Post by Fox on May 1, 2010 18:14:25 GMT -5
That's a weird engine. Are there any numbers stamped on the case anywhere? Sometimes the numbers are on the rear of the gear box
Can you remove the gear from the pump shaft or the entire shaft and re-install it?
It looks like that hole goes into the crankcase/fuel area
Post by pgopmx74820 on May 1, 2010 18:30:57 GMT -5
Post by pgopmx74820 on May 2, 2010 1:53:25 GMT -5
im now looking to make it run better with clutch springs and torque spring . what size should i be getting for a big guy like me at 270. looking for better take off speed and better cruising speed too. i will probably be adding these too Performance roller polygon sliders 15x12. they on the scrappydog scooter page
Post by 90GTVert on May 2, 2010 5:58:30 GMT -5
Looking at the diagram, I'm noticing other differences. Maybe soemone that's seen more 2Ts than me will know what you've got for sure.
A stock cylinder will probably like a 1000 or 1500 RPM contra. I'd hold off on ordering that or the sliders until you know what fits for sure though.
Post by pgopmx74820 on May 2, 2010 14:27:21 GMT -5
thinking i might just give up darn thing only wants to flood the spark plug and not run go figure
Post by 90GTVert on May 2, 2010 14:40:10 GMT -5
Was it having problems before you removed the oil pump or just after? Might wanna go back and make sure you didn't disconnect anything. Check for spark.
Post by pgopmx74820 on May 2, 2010 14:51:15 GMT -5
it ran good after the change yesterday we rode it around all day, had same idea so put it all back normal and still drowns the plug
