Post by sublunacy on Jan 16, 2016 12:42:09 GMT -5
IF ITS AN MX PISTON REED ENGINE-
you can lower the inlet floor slightly MAYBE. but dont raise the roof at all. it can go wider to match a larger carb and increase performance everywhere.
dont touch the transfers at all.
the exhaust manifold should match the carb and cyl ex outlet in size.
after that is all done you can raise the ex port 1-2mm to increase over rev. but the ex port area should not be more than 20 percent larger than the ex manifold or carb etc.
your mx cylinder is a hybrid of piston port engines and case reed engines. your mx piston holds back the inlet charge to build up vaccuum pressure so when it opens it gets a gulp of air and excellent carb signal. thats it....
Post by sublunacy on Jan 16, 2016 16:06:48 GMT -5
i will add that the carb can be 20 percent smaller than the exhaust outlet and ex manifold. it seems more confusing explaining it that way.
measure ex manifold THAT is Q
---------AREA-------- cylinder outlet =Q cyl ex port area=Q+ 20% tranfers do not touch. inlet area=? depends on model and carb size carb=Q - 20%
---------PORT TIMING------- IF YOU INCREASED Q- raise the exhaust port to increase port time open. and maybe the inlet floor. IF Q IS STOCK- dont raise the exhaust port. dont change the inlet floor.
let me know if you need clarification somehow. i will want pictures b4 i tell you to lower the inlet floor.
Post by sublunacy on Jan 16, 2016 17:01:10 GMT -5
IF ITS A CASE REED ENGINE- ask me again because i just explained everything for a piston reed engine. maybe i got the question wrong somehow.
Post by PIG on Jan 18, 2016 18:17:51 GMT -5
Post by spaz12 on Jan 18, 2016 18:28:38 GMT -5
I don't see why it wouldn't work.
Post by 190mech on Jan 18, 2016 19:15:41 GMT -5
Heck yeah,splice that baby,gotta be better than nothing,perhaps better than Stage 6 made it!!
Post by sublunacy on Jan 18, 2016 19:56:31 GMT -5
the header is 8 inches too long. so it will run hot untill the silencer is shortened 4 inches and it still will not be right.
expect a 4000 rpm peak hp and melted piston at 8000rpm
Post by PIG on Jan 18, 2016 20:03:07 GMT -5
the header is 8 inches too long. so it will run hot untill the silencer is shortened 4 inches and it still will not be right. expect a 4000 rpm peak hp and melted piston at 8000rpm Really? The header is 4 inches longer then the pipe originally was.
Post by 'O'Verse on Jan 18, 2016 20:34:36 GMT -5
Nice splice.... Is that Snakeskin duct tape?
Post by sublunacy on Jan 18, 2016 21:52:01 GMT -5
yea/ i should have said 4 inches but the rest i stand behind. peak power lowers a 1000rpm for every inch added.
Post by sublunacy on Jan 18, 2016 21:53:41 GMT -5
and remove a 1/2 inch of silencer for every inch added to the manifold. your cvt transmission will be nothing but problems.
Post by PIG on Jan 18, 2016 22:08:25 GMT -5
I'm not worried about the CVT I'm pretty good at setting them up. Do think the actual S6 vertical pipe that they make is that much different in length then what i pieced together here? The header pipe has to be real close in length no? And I doute they make two different silencers for the horizontal and the vertical.
Post by sublunacy on Jan 18, 2016 22:24:18 GMT -5
i have done it. and thats similiar to what was described to me while i messed with it.
put it in the pit or get it within a quarter inch of correct.
Post by PIG on Jan 18, 2016 22:38:16 GMT -5
Thanks for all the info man, I really appreciate it. I have few silencers laying around that might be shorter. If not I'll cut this one down.
Thanks again.
Post by sublunacy on Jan 19, 2016 0:06:12 GMT -5
proarturs is selling a leovince tt. you could probably get it for 50 dollars.
