Post by Sitticuss on Feb 22, 2014 14:44:13 GMT -5
I replaced the bearing and oil seal. Didn't touch the needle bearing I don't see a problem with it. Plus all of ebay and amazon didn't have one. I did find a few but their kind of pricey. Since replacing the other bearing the drive shaft no longer rubs against the gear box.
Post by moofus02 on Feb 22, 2014 22:41:41 GMT -5
Man I'm sorry went or and looked at that center stand it's cracked got about a 20°twist in it and the pivot holes are all egged out. I don't believe it's worth shipping cost
Post by Sitticuss on Feb 23, 2014 7:03:31 GMT -5
Thanks for looking.
Post by Sitticuss on Feb 23, 2014 7:27:11 GMT -5
My 1K Hoca contra spring doesn't seem to have the same tension anymore. I think i should have installed a 1.5k since there seems to be some fading in spring tension pretty quickly. I would appreciate anyone with experience in this area chiming in...
Post by 90GTVert on Feb 23, 2014 7:49:00 GMT -5
CVT cover venting will help reduce spring fade. Any belt or clutch slip creates a lot of heat and makes it worse. You could try lighter rollers/sliders if you have them instead of replacing the contra spring. I usually use a 1000RPM contra spring in my stroker setups.
Post by Sitticuss on Feb 23, 2014 9:52:37 GMT -5
Went out for a test run.. Heard a clicking/grinding noise when I turned it over with the starter. Everything looked good when i put the CVT back together Obviously it wasn't. I also swapped out the carb i was using with a clone of the same carb. The needle is longer with a much longer taper angle. I was just curious to see how this would change performance. But gas started coming out of the overflow as soon as I turned the motor over. So the float is clearly sticking.
But so far no leaking from the gearbox. I got to get this thing going because today is such a sweet day for testing. Hot and humidity is high with no wind. Typical Florida weather...
Post by Sitticuss on Feb 23, 2014 10:38:01 GMT -5
Found the source of that noise. Not sure how this happened.
Post by Sitticuss on Feb 23, 2014 10:44:00 GMT -5
Not sure how this compares with everyone else but here it is. Looks like there is room for improvement.
Post by Sitticuss on Feb 23, 2014 10:48:20 GMT -5
Pretty narrow down here from what I am used to seeing on my other scoot. Also seems to be alot of belt dusting already not a good sign IMO.
Post by moofus02 on Feb 23, 2014 11:06:55 GMT -5
Looks like room for improvement. Down in the front out in the back. Is that a stock variator or aftermarket. Sent from my SPH-L720 using proboards
Post by cn6301 on Feb 23, 2014 11:08:39 GMT -5
On my 90 I think it came with a barrell spacer that was on the shaft with the cvt. The barrel is about 1/2 long and the same diameter of the wrist pin thing ( what ever its called) that the cvt rides on. Dont know if that makes a difference.
Post by moofus02 on Feb 23, 2014 11:14:05 GMT -5
Some shims to make the drive boss a touch longer would help
Post by Sitticuss on Feb 23, 2014 11:15:24 GMT -5
Swapped out the 6g rollers for 5g sliders the lightest I have around. The build the way it is seems to prefer lighter vs Heavier. I would love to toss a Hoca variator in, but it's not in the budget right now. Also a look at my soon to be patented variator tool works good as long as your careful not to grab a fin
Post by moofus02 on Feb 23, 2014 11:18:51 GMT -5
I use a rubber strap wrench
Post by Sitticuss on Feb 23, 2014 11:19:20 GMT -5
Looks like room for improvement. Down in the front out in the back. Is that a stock variator or aftermarket. Sent from my SPH-L720 using proboards It's the stock variator. Could benefit from a couple shims. But I don't have any on hand.
