Post by Sitticuss on Feb 23, 2014 11:44:37 GMT -5
Plus after installing the CVT cover I noticed there is very little room to shim...
Post by Sitticuss on Feb 23, 2014 12:14:10 GMT -5
Both carbs made in japan one on the left is newer. they both share the same basic design but the internal parts are different. There is also a clear difference in the needles.
Post by 2TDave on Feb 23, 2014 13:45:52 GMT -5
Looks like your pretty far down on the rear pulley. Shims should help. I made one with a washer drilled out. 1.4 mm.
Post by Sitticuss on Feb 23, 2014 13:52:33 GMT -5
Went out for another test run. Lowered the needle one notch helped the bogging on takeoff. As for max speed....49mph at 7800 rpm speedo....51 GPS....
Post by Sitticuss on Feb 23, 2014 13:59:37 GMT -5
Looks like your pretty far down on the rear pulley. Shims should help. I made one with a washer drilled out. 1.4 mm. I'm barely clearing the Kick start now by around 1 mm.
Post by 2TDave on Feb 23, 2014 14:04:30 GMT -5
Gotcha. Where in Fl. Are you. It's low to mid 80's here in Stuart.
Post by Sitticuss on Feb 23, 2014 14:08:25 GMT -5
Gotcha. Where in Fl. Are you. It's low to mid 80's here in Stuart. I live in Naples... 85 here now and the women are out in their skimpy beach clothes
Post by 2TDave on Feb 23, 2014 14:12:24 GMT -5
I need to take a ride to the beach. Wish I had a heads up system so I could watch this race and ride. A ride to meet around Clewiston would be cool if there were some more So. Florida riders around.
Post by Sitticuss on Feb 23, 2014 14:33:18 GMT -5
I believe the reason my belt has a tendency to want to slip is because of how polished the drive surfaces on the variator have become. Aren't they supposed to be a little rough? What final grit would you use if you were resurfacing one....220?
Post by 90GTVert on Feb 23, 2014 15:09:47 GMT -5
220 would be OK. They can be smoother than that and work fine, but shouldn't be polished.
Post by Sitticuss on Feb 23, 2014 17:45:24 GMT -5
Found another drive shaft oil seal that's leaking. I'm sick of messing around with this gearbox... Its time for all new bearings and seals. I've got a BBK coming in a few days going to drop this motor out and put the other one back in for now.
Secret 90
Feb 23, 2014 20:27:52 GMT -5
via mobile
Post by nelson on Feb 23, 2014 20:27:52 GMT -5
Nice man 51 mph is doing good.
Post by aeroxbud on Feb 24, 2014 8:28:03 GMT -5
That is tight to the cover, 51mph is pretty good
Post by Sitticuss on Feb 24, 2014 11:03:35 GMT -5
I need to replace the shock bushing on my 50cc.. but i can't find the section where 90GTVert was kind enough to list all the bearings etc....I must be getting old I gues I should start using that fancy bookmark thingy
Post by 90GTVert on Feb 24, 2014 12:17:11 GMT -5
