Post by moofus02 on Jan 23, 2015 14:14:57 GMT -5
Hey i don't remember was that a long case bike to start with? You going with the little 10 in wheel and tire or moving up to a bigger setup with the longcase motor?
Post by Sitticuss on Jan 23, 2015 14:45:16 GMT -5
Yes it was a long case. I'm going back to the 12" rims I have
Post by moofus02 on Jan 23, 2015 14:57:22 GMT -5
You want to get rid of the shortcase atv gears?
Post by Sitticuss on Jan 23, 2015 15:14:54 GMT -5
You want to get rid of the shortcase atv gears? Sent from my SPH-L720 using proboards no. I'm going to keep it intact.
Post by moofus02 on Jan 23, 2015 15:25:17 GMT -5
Now you need a jog for the shortcase
Post by Sitticuss on Jan 25, 2015 7:03:40 GMT -5
Ordered a ton of parts. Good thing this isn't a flip. Even got a new rear rim. The price made me wish I had a 19 spline axle. Parts for scooter had a sweet set of 13" rims I was drooling over.
Post by Sitticuss on Jan 25, 2015 7:06:28 GMT -5
Now you need a jog for the shortcase Sent from my SPH-L720 using proboards Maybe eventually. I'll end up storing the 90cc short case away for a rainy day. I need a scooter thats more suited to speed around here. I think the long cases are better for that IMO.
Post by Sitticuss on Jan 25, 2015 13:12:25 GMT -5
Post by Sitticuss on Jan 25, 2015 17:03:08 GMT -5
Post by Sitticuss on Jan 25, 2015 17:07:34 GMT -5
Also this might have been a problem.. Not sure what happened there. I'm sure that piece probably ended up in a bad place. I think this cylinder will be coolz with a little work. And a new piston and rings
Post by moofus02 on Jan 25, 2015 17:35:32 GMT -5
I'm sure that had gasket venting to the stud was an issue looks like it will clean up
Post by 190mech on Jan 25, 2015 18:09:19 GMT -5
Brent recently had some headgasket troubles,think he went to copper instead of aluminum to cure it..
Post by 90GTVert on Jan 25, 2015 18:46:22 GMT -5
I was using a really narrow aluminum gasket. 0.5mm thick, but skinny. I haven't had any problems directly related to the more robust head gaskets and really there were other things going on with the narrow gasket in place... but I don't plan to use anymore of them still.
Post by Sitticuss on Jan 25, 2015 19:30:16 GMT -5
I'll stick to the copper gasket myself this time
Post by Sitticuss on Feb 1, 2015 19:40:36 GMT -5
I offered my wife the spare 80cc engine or my 103cc out of my scooter, since I hit a snag on my redneck build. I'll be pulling the motor out of my scooter tuesday.... Got the body panels all removed and mostly painted. I can't find that light that goes in the middle just above the front tire. So I figured maybe a new mini LED spotlight.
