Post by moofus02 on Jan 27, 2014 19:27:07 GMT -5
Sorry I'm tired China 90 shortcase I've got one be Wednesday before I could get it out to you
Post by Sitticuss on Jan 27, 2014 19:34:34 GMT -5
That would be great...Just let me know the damage and i will gladly pay you for it....
Post by moofus02 on Jan 27, 2014 19:41:48 GMT -5
No problem it's too cold tonight and I'm leaving in half hour. I'll pull it when I get back. Pm me a mailing address
Post by moofus02 on Jan 28, 2014 22:51:54 GMT -5
Got it pulled just need shipping info
Post by Sitticuss on Jan 29, 2014 5:57:34 GMT -5
sent the pm....thanks again moofus
Post by moofus02 on Jan 29, 2014 9:04:38 GMT -5
Got it I'll get that out at lunch
Post by moofus02 on Jan 29, 2014 13:55:40 GMT -5
Pin in the mail
Post by Sitticuss on Jan 31, 2014 15:42:27 GMT -5
got the part today....looks like it will work great
Post by moofus02 on Jan 31, 2014 20:41:42 GMT -5
got the part today....looks like it will work great Glad to be of some help Sent from my SPH-L720 using proboards
Post by Sitticuss on Feb 2, 2014 0:30:30 GMT -5
Got all the part in today to finish installing the brake etc on the rear end. Started modifying the CVT cover. Installed the new piston and put the top end back together. The speedometer broke. Checked it out and determined the problem is in the instrument cluster its self. I wanted to get a trail tech vapor for it, but the wife said it looks ugly. So now i am on the hunt for a new speedo that isn't ugly, digital and back lit. Will post some pictures tomorrow.
Post by 2strokd on Feb 2, 2014 12:04:50 GMT -5
I have a Koso unit that measures MPH and trip etc, but also can do 1/8th, 1/4 mile, etc tests. You can program it to run any set speed and record ET. For instance, mine is set for 1/8th mile (200meter) runs. For the speed test i have it set to time my 0-30MPH runs. They are kinda pricey but after 4 years of use i can say i think they are worth it. I have had no trouble at all out of it. Easy to set up, easy to use. You can find them at SIP or about any other big retailer for around $100
Post by 2strokd on Feb 2, 2014 12:07:19 GMT -5
Post by 2strokd on Feb 2, 2014 12:08:19 GMT -5
Secret 90
Feb 2, 2014 12:44:32 GMT -5
via mobile
Post by 2TDave on Feb 2, 2014 12:44:32 GMT -5
I found an o.e.m. LCD unit for Ventos with tach and fuel cheap. If your running bare bars mounting would take some work.
Post by Sitticuss on Feb 2, 2014 19:28:04 GMT -5
This is what i am dealing with at the moment.The lens is the best i can get it even after buffing and cleaning but at least i can see through it now. I just mounted my tach temperalily with some velcro tabs. If this was just my scooter i would strip it down to the bars and just install some $20 needle gauges.
