Secret 90
Feb 2, 2014 19:52:29 GMT -5
via mobile
Post by 2TDave on Feb 2, 2014 19:52:29 GMT -5
Yeah you'd have to do some work on the plastics to use what I ordered but for under 40 bucks it may be worth it. There is a pic in my Strada build thread.
Post by Sitticuss on Feb 2, 2014 20:34:01 GMT -5
Under 40 sounds good to me i will check it out.
Post by Sitticuss on Feb 2, 2014 21:07:07 GMT -5
Not something i like to see....... I'm guessing there should be a washer here between the gear shaft and the bearing?
Post by Sitticuss on Feb 2, 2014 21:25:14 GMT -5
Din't see where this washer fit in..........
Post by Sitticuss on Feb 4, 2014 19:58:18 GMT -5
Turns out i ordered the wrong size brake pads for the rear tire. The rear wheel has the same number of splines but different size splines.
Post by Sitticuss on Feb 4, 2014 20:00:21 GMT -5
2Tdave turns out they used that speedo on some versions of my scooter. I went ahead and ordered one thanks for the help.
Post by Sitticuss on Feb 4, 2014 20:07:14 GMT -5
There is some back and forth movement for the rear drive shaft. Is that normal?
Secret 90
Feb 4, 2014 20:34:15 GMT -5
via mobile
Post by 2TDave on Feb 4, 2014 20:34:15 GMT -5
Glad I could help. The outline looked different.
Post by Sitticuss on Feb 4, 2014 20:40:57 GMT -5
I will have to rework the plastics but it will be a nice upgrade.
Post by 2strokd on Feb 5, 2014 11:45:44 GMT -5
There is some back and forth movement for the rear drive shaft. Is that normal? Yep, the CVT cover support bearing will hold it firm. Too much play means it might need a bearing or seal? If its smooth and only has a couple mm,s play with a good oil seal i would not worry. Make sure that cover bearing is smooth as well.
Post by Sitticuss on Feb 5, 2014 17:48:39 GMT -5
Post by Sitticuss on Feb 5, 2014 17:49:15 GMT -5
Post by moofus02 on Feb 5, 2014 18:04:41 GMT -5
Looking good
Post by 2strokd on Feb 5, 2014 18:09:11 GMT -5
I like the covers on the cover lol..
Post by nelson on Feb 6, 2014 14:16:03 GMT -5
what pipe do you plan on running? can you also post where you are getting the inserts that go in the engine to mount it? This engine is going in your wifes bike?
