Post by Lucass2T on Jul 13, 2016 17:22:27 GMT -5
Bought these today. I was still using an old dried out Dunlop TT92 up front and some cheap tire on the back which I did a burnout with and is totally bald now The conti's can handle speeds up to 130km/u (80mph). I picked a wider and flatter size for the backwheel.
Post by spaz12 on Jul 13, 2016 17:23:39 GMT -5
Nice tires
Post by Lucass2T on Jul 13, 2016 17:41:41 GMT -5
Post by Lucass2T on Jul 24, 2016 11:00:52 GMT -5
Seems like im going back to stock for now. The engine was rattling eventhough nothing was wrong before I took the cylinder off. I took it off again and noticed the flat top piston had a dimple on the top. Ill make pics later.
So now im back to a stock motor and maybe ill build a new watercooled engine in the winter. Probably gonna be something like a Polini evo 70 - Yasuni c20 - Mikuni TM24 kinda setup. Leaving the rest as is.
Post by spaz12 on Jul 24, 2016 12:32:02 GMT -5
That's a bummer. You haven't even gone on your trip yet have you? The Polini Evo and C21 combo sounds nice.
Post by Lucass2T on Jul 24, 2016 14:07:44 GMT -5
That's a bummer. You haven't even gone on your trip yet have you? The Polini Evo and C21 combo sounds nice. No thats august 7th. I gonna ride it with my stock engine. I was thinking of putting the Metrakit pipe under but i don't feel like tuning the engine now just before the roadtrip and i'll loose my center stand. ATM i don't want any insecurities and possibilities that can cancel my participation in the roadtrip.
Post by Lucass2T on Aug 11, 2016 16:02:22 GMT -5
Little preview from the roadtrip (which is still going on)
Post by oldgeek on Aug 11, 2016 16:04:33 GMT -5
That sucks! I hate it when they look like that.
Post by tsimi on Aug 11, 2016 18:52:45 GMT -5
WTF? What happened? And how are you gonna get that fixed?
Post by nelson on Aug 11, 2016 19:16:50 GMT -5
Your missing a c-clip That sucks
Post by ryan_ott on Aug 11, 2016 19:25:32 GMT -5
Your missing a c-clip That sucks No he's not its smeared into the side of his piston. Was that the motor you have been running or your stick bore you mentioned going to.
Post by spaz12 on Aug 11, 2016 19:40:42 GMT -5
Ouch.
Post by Jwhood on Aug 11, 2016 20:46:01 GMT -5
I hate when that happens had one do that and it weld the piston to the inside of the bore
Post by 'O'Verse on Aug 11, 2016 21:14:58 GMT -5
Your gonna try and run that piston again right!
Post by Lucass2T on Aug 14, 2016 4:36:18 GMT -5
WTF? What happened? And how are you gonna get that fixed? Well...i pushed the engine over it's limit when going full throttle down a steep road to see how fast it would go I made a video of that by the way! I think it got so hot that the piston got a little soft. The piston clips' seat got distorted and it could get out to end up between the piston and the cylinder. The upper ring locator pin also moved up in the piston. It's funny though, it didn't suffer lubrication or cooling problems as you can see in the pics below. I didn't overheat or seize it because there's no scuffing anywhere...it's just the piston failing and not being up for the job. It's difficult to see but the groove where the piston pin clip normally sits got wider and lost it's hold on the clip Also look at te upper piston ring locator. It moved up 2 mm's or so. That ring was on the verge of ending up in a port. I ended up buying a whole new cylinderkit. The damaged cylinder and piston weren't usable with the basic tools and short time available at that moment.
