Post by nelson on Mar 29, 2015 15:26:47 GMT -5
I have had good luck with koyo and gag. Both can be found here on amazon without any bs just put measurements in and look around
Post by oldgeek on Mar 29, 2015 19:10:53 GMT -5
I know some guys order from vbx.com. I try to keep four crank bearings at a time lying around. Yup, it is nice to be able to have spare parts on hand for when you need them. If these bearings were not krap I would have 3 sets ready to go.
Post by oldgeek on Apr 17, 2015 22:56:21 GMT -5
WoW! The shock I ordered way back finally came yesterday. I got it installed on the Zip tonight, but could not test ride very far due to the rain. I almost dumped it on the test ride! I have been riding on the front of the seat due to the bad shock, I moved to the back of the seat and hit the throttle way too hard and pulled the front wheel way off the ground very unexpectedly.
I also resealed the airbox to carb hose where it enters the airbox. I hope that will fix the bog I recently developed just off idle, otherwise I guess I will pull the carb and give it a good cleaning.
Post by oldgeek on Apr 27, 2015 21:43:58 GMT -5
I got motivated for some reason after work today. I got the motor pulled from zip so I can split the cases and replace the crank bearings. I also went through the gearbox because the gear oil was rough looking, and the gearbox has been getting a little hotter than it should. Everything was perfect, and I found the cause of the heat and dark oil. Apparently I had the back brake just a little tight and it was dragging slightly.
Post by Sitticuss on Apr 28, 2015 1:24:24 GMT -5
what a drag.....
Post by thatcrazyguy on Apr 28, 2015 12:31:16 GMT -5
Do you happen to know the gear ratio on the zip? Is it 10.3:1 like the tritons?
Post by moofus02 on Apr 28, 2015 16:16:09 GMT -5
Do you happen to know the gear ratio on the zip? Is it 10.3:1 like the tritons? I think the zip is shortcase if so the common gear ratio on the shortcase is around 11:1 Sent from my SPH-L720 using proboards
Post by niz76 on Apr 28, 2015 16:32:20 GMT -5
The gears I pulled out of a Vento Zip parts scoot were 11:1 like Moofus mentioned.. I'm running them in my (96cc) scoot and getting 60 mph at 8200 RPM (with a modified vari also) A pretty good ratio!
Post by moofus02 on Apr 28, 2015 17:08:35 GMT -5
The gears I pulled out of a Vento Zip parts scoot were 11:1 like Moofus mentioned.. I'm running them in my (96cc) scoot and getting 60 mph at 8200 RPM (with a modified vari also) A pretty good ratio! Ya but that's in the adly 90 right? Longcase with shortcase gears and 12 inch wheel. Still Brent was running that gear in a shortcase Polaris 90 and getting those speeds but at a higher rpm if i remember right Sent from my SPH-L720 using proboards
Post by thatcrazyguy on Apr 28, 2015 17:22:21 GMT -5
Ok thanks niz & moof
Post by thatcrazyguy on Apr 28, 2015 17:22:52 GMT -5
Where did Brent find a 90 shortcase? Ive been looking everywhere lol
Post by nelson on Apr 28, 2015 17:33:59 GMT -5
Where did Brent find a 90 shortcase? Ive been looking everywhere lol 2002 polaris sportsman and or scrambler 90
Post by thatcrazyguy on Apr 28, 2015 17:51:07 GMT -5
Does any site sell the hole engine intact? I looked on ebay and its all parts
Post by niz76 on Apr 28, 2015 18:09:10 GMT -5
Post by Jwhood on Apr 28, 2015 18:47:13 GMT -5
Damn I can't ever find a deal on a 90 like that,niz buy it and sell it too me for a decent price?? Lol
