Post by 2TDave on Jul 7, 2014 19:12:11 GMT -5
It should be fine but it probably wouldn't cost anything and it may give you a little peace of mind.
Post by craisin on Jul 7, 2014 21:37:20 GMT -5
Make sure you don't have a kink or pinch in the fuel line Sent from my SPH-L720 using proboards Interesting suggestion... I took off the seat bucket and realized I had pinched a vacuum line between the seat bucket and where it gets bolted down. I was expecting a kinked fuel line. This would still cause the lack of fuel and cause it to run lean... Right? I'm new to mechanical stuff... Health care provider so I'm better at fixing the human body welcome we need Health care providers
Post by FrankenMech on Jul 7, 2014 21:50:58 GMT -5
Look at it like a partially obstructed coronary artery. At idle it works 'OK' but with any demanding exercise it__________
Post by craisin on Jul 8, 2014 4:07:53 GMT -5
Maybe tomorrow will be a better day Frank
Post by FrankenMech on Jul 8, 2014 4:34:41 GMT -5
I was speaking of the 'obstructed vacuum line' and putting it in more 'human body' terms for our health care provider.
Post by craisin on Jul 8, 2014 4:58:08 GMT -5
oh right today i soldered 2 wires and did another 10 minute job and that was it for the day.
Post by lykolate on Jul 8, 2014 10:34:45 GMT -5
So I got rid of the bad coronary artery and just installed a manual petcock and sealed the vacuum intake... But it still is stalling at quick stops and now has a harder time starting. Doh. And there's a weird noise coming from CVT / air filter area
Post by 2TDave on Jul 8, 2014 12:03:18 GMT -5
Rode to work.
Post by 90GTVert on Jul 8, 2014 13:48:04 GMT -5
I made a decision to move to the yellow center line when a truck in front of me was turning on a road with no shoulders and an SUV was coming the other way and I was doing 50MPH. I'm quite glad the truck finally started turning into his driveway so I could move over a bit before meeting the SUV, because I don't think the initial choice was a good one at all. I was just making a quick test run to see if the sliders I had in would work and the truck was a neighbor from 1/2 mile away so I knew he was going to turn and that's why I didn't slow down. The surprise was he decided to sit in the road rather than just pull in for whatever reason. One of those brain farts where I know better than to trust anyone else on the road to do what I expect but I did it anyway and it coulda bit me in the ass so to speak. Of course it was just going to be a 3-4 mile quick run and I wore the helmet without a cam so that was bad decision 2... or 1 really because it happened first. So I got rid of the bad coronary artery and just installed a manual petcock and sealed the vacuum intake... But it still is stalling at quick stops and now has a harder time starting. Doh. And there's a weird noise coming from CVT / air filter area I know noises are tricky, but any further explanation?
Post by lykolate on Jul 8, 2014 16:51:49 GMT -5
Can't say but it was kind of high pitched/scratchy-screechy like but hasn't returned since the first two starts since completing these changes. I'm wondering if I don't have the fuel line vertical enough .
Post by 2TDave on Jul 8, 2014 17:13:53 GMT -5
Rode home from work. I've got a little hesitation of the start and the revs don't seem to be going up as fast. I just put a 100 main in down from 102. It's hot and humid as all get up here so I'll take a test ride and see what it feels like.
Post by craisin on Jul 8, 2014 17:54:12 GMT -5
www.gadgetjq.com/keihin_carb.htmSo I got rid of the bad coronary artery and just installed a manual petcock and sealed the vacuum intake... But it still is stalling at quick stops and now has a harder time starting. Doh. And there's a weird noise coming from CVT / air filter area This carb in the link is not scooter carb but it has the same principles ,Scroll down to Coasting Enrichner feeding a closed mouth. there nothing much in the air filter to make weird noises except a rubber restriction i was told to raise the carb needle one notch and remove it ,So the circlip goes down one notch on the needle. I would be careful not to lose the diaphram spring
Post by craisin on Jul 8, 2014 18:11:23 GMT -5
Can't say but it was kind of high pitched/scratchy-screechy like but hasn't returned since the first two starts since completing these changes. I'm wondering if I don't have the fuel line vertical enough . There is a fan on the variator that sucks air into the CVT you could have sucked a leaf or part of a leaf in
Post by Nokatay on Jul 8, 2014 20:21:58 GMT -5
Removed handlebar cowl to tighten left brake lever bracket and I snapped a cowl to handlebar snap thingy. These Chinese body plastics suck. I'll fab an epoxy repair next time cowl comes off. I also decided (for later) to drill a couple of lower body screw threads (the part the screw threads into)that were stripped when I got the bike. A squirt of epoxy, time to dry and redrill to accept screws securely oughta' do it. Of course a test drive was neccessary (right even if you just check the oil ya' gotta' test ride!) and I was cut off by two vehicles leaving a parking lot. I woulda' just shrugged it off it wasn't a couple of dorks on SCOOTERS! lol.
Post by FrankenMech on Jul 8, 2014 22:01:37 GMT -5
A filled epoxy like JB Weld works best for filling screw holes etc.
