Post by niz76 on Aug 22, 2014 18:35:57 GMT -5
3MPH difference from BBK + pipe vs a variator is really good. Not too bad eh? I have my eye on the Malossi (sport?) BBK combo'd with my home-made Stage6 Pro pipe- oohhhh can't wait! (Rubbing hands together in a devilish fashion ) OK, after doing a bunch of late-night research last night on Name brand BBK's, now I'm thinking I want to go with the Stage6 Sport Pro MKII.... but it seems that coupled with the (home-made) S6 Pro pipe, that I should probably upgrade my crank then? Yep, yep scoot tuning IS like crack lol. Here's the article that chaNged my mind from the Malossi kit... HERE.
Post by 2TDave on Aug 22, 2014 18:43:46 GMT -5
I have that cylinder on my other motor and ran it with a Yasuni C16 and the stock crank. I hit 10.5k rpms regularly but never held it there long. I hit 11.3 a couple times. I think the stock crank can handle it unless you plan on dogging it. Just my two cents Niz.
Post by niz76 on Aug 22, 2014 20:30:23 GMT -5
Awesome. Thanks 2TDave- exactly the review info I was looking for from someone who has hands-on experience with this kit. If I remember correctly I think the C16 revs a little higher than the S6Pro.. I think the Stage6 stickers will look better on my scoot than the Malossi ones anyways.
Post by niz76 on Aug 22, 2014 23:04:44 GMT -5
Ummm This is kinda weird. Look what I found in my scoot's headlight. Alien.
Post by 2TDave on Aug 23, 2014 5:26:16 GMT -5
Don't feed it after midnight.
Post by 2TDave on Aug 23, 2014 5:29:51 GMT -5
Awesome. Thanks 2TDave- exactly the review info I was looking for from someone who has hands-on experience with this kit. If I remember correctly I think the C16 revs a little higher than the S6Pro.. I think the Stage6 stickers will look better on my scoot than the Malossi ones anyways. I have to put a disclaimer in to cover my a$$. I relate only my experience and do not warrant my words.
Post by vlatx on Aug 23, 2014 7:19:29 GMT -5
Stage 6 all the way.
Post by 2TDave on Aug 23, 2014 11:38:05 GMT -5
The MKII dyno charts are even better.
Post by niz76 on Aug 23, 2014 14:24:25 GMT -5
Awesome. Thanks 2TDave- exactly the review info I was looking for from someone who has hands-on experience with this kit. If I remember correctly I think the C16 revs a little higher than the S6Pro.. I think the Stage6 stickers will look better on my scoot than the Malossi ones anyways. I have to put a disclaimer in to cover my a$$. I relate only my experience and do not warrant my words. "...But 2TDave said it could handle it.." lol I know the risks of running the stock crank at high RPM's.. it makes me feel better knowing that someone else has run this kit with a stock crank too. I see in my crystal ball that at some point I will probably end up with a spare 2T Minarelli on my workbench that I can take my time with and build up.. 2T bug bit me hard and hasn't let go
Post by 2TDave on Aug 23, 2014 14:55:06 GMT -5
I know the feeling. That's exactly what I did. Built a nice street motor with a good pipe I could use later. Then got a spare motor and did a complete build. Still have a good running sport pro Mkii motor should I need it. Hope I don't! If you have a large spline and taper now Stage6 makes an HPC crank so you don't have to buy a new flywheel and variator like I did with the R/T crank.
Post by niz76 on Aug 23, 2014 21:20:48 GMT -5
So today I started to address an issue on my scoot that has been bugging me; COSMETICS! I took the front fender off my scoot. As you can see it's sun faded and nasty. There's barely any clear coat left on it. I'm not much of a pro painter by any means. I can get a decent paint job from a rattle can, but this is my baby and I want it to look good! I decided on a paint scheme and sprayed it out. I sprayed clear coat but wasn't happy with the finish. How do some guys get such a nice paint job from the same paint?? I headed over to Youtube and got myself edumacated... So I guess the secret is wet sanding. Aha! I wet sanded between coats and also wet sanded the orange peel out of the clearcoat the best I could. I only have 1000 grit for my finest sandpaper. I finished off by buffing everything out with Meguiars headlight restore compound that I had... It turned out great! This is probably the most effort I've ever put into a paint job ever, and although I made plenty of mistakes on this piece, I am pretty proud of the outcome The rest of the scoot should come out even better!
Post by 2TDave on Aug 24, 2014 5:33:45 GMT -5
Nice work! Not one of my better abilities.
Post by 90GTVert on Aug 24, 2014 22:03:22 GMT -5
Looks great. Clean edges on the detail work and all.
Post by niz76 on Aug 25, 2014 12:43:55 GMT -5
Post by 2TDave on Aug 25, 2014 14:00:35 GMT -5
Looks good! What's the story with that left brake lever? Is it rubber! Lol
