Post by craisin on Sept 6, 2014 15:00:37 GMT -5
looks good be good to see its final state
Post by Clank on Sept 6, 2014 18:46:13 GMT -5
Vroom Vroom Vroom, oh oh sorry daydreaming.
Post by Clank on Sept 6, 2014 18:47:17 GMT -5
Back to the grindstone.. .
Post by Clank on Sept 6, 2014 18:50:36 GMT -5
Special thanks to Jimmy at Sierra Welding Supply for the killer discounts & all in all good prices. And a Extra Thank You Thank You to Upgrayedd for those dimensions. Would've been stuck even longer, thanks bro.
Post by Clank on Sept 6, 2014 18:55:13 GMT -5
:lmao:
Post by Clank on Sept 6, 2014 22:23:49 GMT -5
Apparently Cali's are into the toe show scene also.must the latitude.
Post by Clank on Sept 6, 2014 22:26:02 GMT -5
Hmmm! surprisingly thier all there.
Post by Clank on Sept 8, 2014 22:39:55 GMT -5
FINALLY!!! Got the motor mounts & shock mount fitted. Being that this frame was probably a1/2" out of square to start with and every time I tried straightening something it would through the other end of even further, it's fitted. It had been a nightmare. I know I've gotten a few dozen more gray hairs from this, but the experience & knowledge I've gained is invaluable.
Post by Clank on Sept 8, 2014 22:46:02 GMT -5
All in all it came out quite a bit lower to the ground than expected, but it runs straight & doing a tilt test every thing clears. Now for the tedious part of finish the welding placing all the components and re-rigging. I'm way past the time I thought it would take but that just falls under learning by trial & error.
Post by katastroff on Sept 8, 2014 22:47:36 GMT -5
Inspiring.
cobracross
Scoot Junior
Working on the 2001 Cobra
Post by cobracross on Sept 9, 2014 0:57:10 GMT -5
This is beautiful. Keep up the great work!
Post by 2TDave on Sept 9, 2014 5:05:48 GMT -5
Looks great Clank!
Post by Clank on Sept 9, 2014 20:15:49 GMT -5
Got the motor mounts welded out and stiffeners in. Had to mod the connecting mount slightly. The lil HF welder does ok, it could be a little hotter. Haven't really messed with it too much. Just set it on high and run the wire about 4.5 to 4.75. It has a really cold start which sucks especially for tacking. But it's getting the job done. If it wasn't something structural as a scooter frame it would probably be fine. Guess I'm gone find out here shortly when I get the Cannonball on the rode. My definition of breaking something in is f#©k¡Ng max it out. If something breaks well it needed to be replaced anyways. Go Big Or For The Sake Of The Rest Of Us Stay Home!
Post by 2TDave on Sept 9, 2014 20:18:02 GMT -5
Damn nice looking welds!
Post by Clank on Sept 9, 2014 20:20:05 GMT -5
It's following the original frame line where it gets wide at the to bend. I'm not liking it the more & more I look at it. Think I'm gonna cut out the upper elbows and rotate them to give me a more flowing line.
