Post by 90GTVert on Oct 11, 2014 8:18:00 GMT -5
Shouldn't be a case gasket, just sealant. Threebond 1184, Permatex Ultra Grey, Permatex MotoSeal 1, and Yamabond #4 are pretty popular choices.
Post by iwiketuddlz on Oct 11, 2014 8:42:29 GMT -5
Oh OK thanks 90G. Well I get off work at 12 then I'm going straight home to get started on the Doppler crank! Wooot wooot thanks guys
Post by iwiketuddlz on Oct 11, 2014 15:12:43 GMT -5
Damn this crank didn't even have bearingss wow ,,...didn't realize that ....sigh
Post by iwiketuddlz on Oct 11, 2014 15:15:39 GMT -5
I'm removing this premix too its so anyoing... What do I mix it? How much per gallon?
Post by 2TDave on Oct 11, 2014 15:45:31 GMT -5
They don't come with bearings. VXB is a good source for Nachi made in Japan.
Post by iwiketuddlz on Oct 11, 2014 19:05:20 GMT -5
OK she s alive!!! Wooot no more knocking at idle,man it sounds good about to yo for a ride ,i just reused my bearings because in a few Months IMA re build it wilth alot better stuff,but until then I will give her hell muwhaha
Post by 2TDave on Oct 11, 2014 19:10:07 GMT -5
How did you remove and reinstall the bearings?
Post by iwiketuddlz on Oct 11, 2014 19:42:22 GMT -5
You sir do not want to know!
Post by iwiketuddlz on Oct 11, 2014 19:42:54 GMT -5
Damn its a beast a lot more torque
Post by 2TDave on Oct 11, 2014 19:45:52 GMT -5
Oh yeah I do.
Post by iwiketuddlz on Oct 11, 2014 20:24:45 GMT -5
I simply used a large chizel to wege in between the bearing and crank wheel the n....pop they both flew off with ez and I'm sure I didn't hurt them any worse than they where
Post by iwiketuddlz on Oct 11, 2014 20:26:40 GMT -5
Well just me me believe I didn't damage them ,but no worries even if they fail I plan on building the crap out of this engine anyway.
Post by 2TDave on Oct 11, 2014 20:27:55 GMT -5
What did you do to get them on the new crank and in the case?
Post by iwiketuddlz on Oct 11, 2014 20:35:00 GMT -5
I used a pipe that same size as the inner part of the bearings and taped them on.then when I got a the case together using a wood mallet I gave both ends of the crank a whack and the crank spins freely...
Post by iwiketuddlz on Oct 11, 2014 20:51:17 GMT -5
I also port matched everything and made a small trench,so at least that part is done when I go to 54mm
