Post by ewasleske on Apr 24, 2015 12:03:23 GMT -5
How will a dent affect the performance of a pipe? Any significant adverse effects? I'm looking at picking up a used Leo Vince ZX .
Post by moofus02 on Apr 24, 2015 13:26:05 GMT -5
If it was for a Zuma the dents are factory for center stand clearance
Post by 90GTVert on Apr 24, 2015 15:32:57 GMT -5
The dents like moofus mentioned on Zuma pipes don't seem to make a difference. If it's a big dent it may be a problem. I showed dent removal from a Zuma pipe in the link below. Don't do it if you have a Zuma or it will hit the center stand. 49ccscoot.proboards.com/post/55781/thread
Post by ewasleske on Apr 28, 2015 11:56:36 GMT -5
I recall seeing a post on acid washing a pipe for rust clean up. Can anyone point me to it? I can't seem to find it! Thanks!
Post by 90GTVert on Apr 28, 2015 15:04:17 GMT -5
Post by ewasleske on Apr 28, 2015 17:06:10 GMT -5
Thanks Brent! Can't wait to try the Mop'n'Glo..
Post by katastroff on Apr 28, 2015 18:27:36 GMT -5
Post by fe53series3 on May 3, 2015 8:46:56 GMT -5
I recall seeing a post on acid washing a pipe for rust clean up. Can anyone point me to it? I can't seem to find it! Thanks! 49ccscoot.proboards.com/thread/11963/peugeot-fe53-series-1994-scootThe acid is phosphoric acid. It is probably the ultimate rust renovator. The difference between phosphoric acid, and other acids, is that it actually converts the rust to something else completely (it's on the web if you google it). The rust becomes a hard black shell, that can then be painted over. In effect, it creates an additional barrier to rust, underneath the paint. It is a must have acid for any workshop dealing with older kit. Buy it at 75%, and mix it no more than 1 part acid to 1 part water........ diluting it to 30% is probably ideal. Buy 1 litre and it will last you a lifetime, as hardly any of it is used. Mix up a tiny amount into a container, each time you use it........ it's as thin as water, so it just spreads. With a brush, spread a coating over the rust, and let it be absorbed. Spread a second coat after it has dried off...... it should be enough...... but a third will definitely do it You'll be left with a beautiful black item (if you like that sort of thing) Note: if you mix it too strong, it will simply etch away the rust, defeating the object..... unless that's what you want it to do. Be very careful with this stuff, and were goggles, against brush spray. Edit: www.thechemicalblog.co.uk/phosphoric-acid-rust-remover/Phosphoric acid acts as a rust converter by changing brown rust (iron oxide) into black ferric phosphate. This black coating can be scrubbed away leaving a new metal surface beneath or it can be left in place in which case it acts as a protection against further erosion.
