Post by renagade281 on Sept 27, 2015 18:25:36 GMT -5
Post by derbiman on Sept 27, 2015 18:29:07 GMT -5
A9 is an aftermarket cam.
Post by katastroff on Sept 27, 2015 18:45:18 GMT -5
A few layers of duck tape and those rollers will be like new.
Post by renagade281 on Sept 27, 2015 18:54:05 GMT -5
A few layers of duck tape and those rollers will be like new. lol does that really work? even with the flat spots on the metal?
Post by katastroff on Sept 27, 2015 18:57:25 GMT -5
hmmm.. not really. Those roller are gone, toasted, dead or whatever you might call something non serviceable.
Post by renagade281 on Sept 27, 2015 19:05:30 GMT -5
didnt think so...im just gonna make this dykon my project scoot... just gonna order all new everything for it bit by bit
Post by aeroxbud on Sept 27, 2015 19:24:34 GMT -5
Never seen rollers that bad before!
Post by renagade281 on Sept 27, 2015 19:46:48 GMT -5
Scoot had 12,000 miles when I got it... Yes 12k And it's a 2011 jonway
Post by 190mech on Sept 27, 2015 19:57:45 GMT -5
Heck!Those are no longer rollers,theyve become 'sliders',,and think folks pay extra for sliders..
Post by renagade281 on Sept 27, 2015 21:29:31 GMT -5
Now it seems as my scooter is slower going up hills and slower on take off. Does that mean the rollers that I put on are lighter or heavier... I guess I should've weighed them before I switched
Post by frank50e on Sept 27, 2015 21:34:07 GMT -5
Do you have a"good" bicycle?
Post by spaz12 on Sept 27, 2015 21:59:25 GMT -5
You went with heavier rollers if it takes off slower, like it's starting in a taller gear? Like starting in 3rd gear, or something like that. Lighter rollers the motor will spin noticeably faster but the scoot will max out on speed quickly, but not have a high top speed. It's a balancing act.
Post by renagade281 on Sept 28, 2015 9:05:22 GMT -5
It just feels like overall the power is not close to what it was before I changed rollers. Like my rpms don't go high at all. I changes the variator and the rear clutch assembly (think that's what it's called. Maybe I will try and put the old on back in and keep the variator
Post by Fox on Sept 28, 2015 14:08:30 GMT -5
You should get a cheapy gram scale so you can stop guessing. www.harborfreight.com/catalogsearch/result?q=scaleOrder a set of 4.5's and a set of 5.5 gram and try them. You can mix them if you want to get a different response. You MUST alternate them in every other slot when you mix weights. You put three 4.5's in every other slot and three 5.5's in the other slots.
Post by ams417 on Sept 28, 2015 14:33:24 GMT -5
I found Doppler rollers on Amazon for reasonable price. Got them next day too.
