Post by Senna1Rossi on Jan 5, 2017 12:14:25 GMT -5
Coldest by far -20*f after windchill. Felt like I had blocks of ice for hands when i got home. The studs are awesome though! Heres a short video
haha, loved the vid. pic of your studded tires, please. does it wash oot at all when you're on just asphalt, and not snow??
Post by themajekalbum on Jan 5, 2017 18:48:07 GMT -5
Mitas mc32 win scoot tires Using the scooter A size in a diffrent/cheaper brand(this brand is $100 for 150, mine were $150 for 250 and the tool) I'll be throwing another snow riding video up once I'm done editing. My ride in today was even more snowy than the above video, 10" worth of snow!
phatmanxxl
Post by phatmanxxl on Jan 5, 2017 20:58:03 GMT -5
I rode in the snow today, but it was a dusting. The bike ran like crap due to being so cold out. Probably need to upjet from 90 to 95. The temp must have dropped when I left to head back home and I was totally underdressed for the ride. It sucked.
Post by Jwhood on Jan 5, 2017 23:23:13 GMT -5
Heading to work in a few on the scoot,snow plowing and shoveling hope the roads are clear and only wet I think they pre treated roads good,I'm in Maryland,clients wanted us out at 1:30 am taking care of lots and sidewalks for tomorrow
Post by themajekalbum on Jan 6, 2017 0:03:10 GMT -5
Another video riding in worse conditions.
phatmanxxl
Post by phatmanxxl on Jan 6, 2017 0:30:14 GMT -5
Does your helmet fog up? I have that problem when I'm not moving. It gets worse the colder it is.
Post by themajekalbum on Jan 6, 2017 0:46:33 GMT -5
I'm using rainx antifog. Works decently. Also heard you can put dawn(dish soap) on, let it dry, then buff it.
Post by Lucass2T on Jan 6, 2017 2:18:41 GMT -5
It's 15 degrees here atm (-10 celcius). And thats kinda cold for this region. I waiting on a pair of hand muffs, I already have some leg warmers ready. I have a warm ski jacket and trousers which work fine for riding.
Id probably still take the car to work though eventhough it's not raining or anything....just because of the cold. Maybe im just spoiled with owning a car.
Post by FrankenMech on Jan 6, 2017 18:48:24 GMT -5
Too darn cold to ride at 13°F here. My scoot is down anyway waiting for an 'upgrade'. The addition of a Vito adjustable jet really helps in cold weather. www.vitosperformance.com/atv_parts/product.php?productid=440&cat=362&page=1It makes it real simple to adjust for changing temps. They seem to jump around from one week to the next. The jet is really easy to install. You will need a 1/4-28 tap and appropriate drill bit if you install it in the carb itself. It can also be installed in the plastic air cleaner tube near the carb.
Post by jkeney on Jan 9, 2017 8:11:22 GMT -5
12 degrees this morning!
Post by FrankenMech on Jan 9, 2017 20:43:42 GMT -5
You need to change your avatar. At 12 degrees something changes from an outie to an inee.
Post by greggkinney on Jan 16, 2017 1:38:00 GMT -5
Too darn cold to ride at 13°F here. My scoot is down anyway waiting for an 'upgrade'. The addition of a Vito adjustable jet really helps in cold weather. www.vitosperformance.com/atv_parts/product.php?productid=440&cat=362&page=1It makes it real simple to adjust for changing temps. They seem to jump around from one week to the next. The jet is really easy to install. You will need a 1/4-28 tap and appropriate drill bit if you install it in the carb itself. It can also be installed in the plastic air cleaner tube near the carb. do you have one if these, if so is it legit to what it claims? is this like an extra jet thats adjustable in the carb? and the exterior mount am i understanding its kind of crude and throws gas in the intake airstream like a wet nitrous fuel solinoid? sorry so many questions but thats how we learn. looks like a great idea for temp changes and maybe spraying a little nitrous. thanks
Post by FrankenMech on Jan 16, 2017 2:57:25 GMT -5
I have one mounted in my carb intake. I would not keep recommending it if I didn't have one. The airflow past the end of the tube siphons fuel through the externally adjustable needle valve just like the main jet in the venturi. It does not just spray fuel. Fuel flow is metered by air velocity and the needle valve. It is very good for weather changes.
I have no idea how it would work for nitrous.
tvnacman
Post by tvnacman on Jan 16, 2017 11:19:36 GMT -5
25 degrees this morning it was a nice ride.
John
Post by Deleted on Jan 16, 2017 12:07:31 GMT -5
I have no idea how it would work for nitrous. My guess is...a tremendous boost in HP for a very short time and then a very loud bang and a lot of hot oil and debris spraying out of the engine. Just a guess of course, ha ha. Bill
