Post by Cincikid on Aug 12, 2017 13:08:23 GMT -5
Seems like fixing that e-start will save you some headaches. A less expensive Dremel(off brand) will work also. Check reviews. Will this do ? Yep. But like others have said use eye protection. When you put the flathead in the slot give it a few med taps with a hammer. Then turn. If it wants to strip start over. WD-40 should help.
Post by tocoo on Aug 13, 2017 7:17:44 GMT -5
Has anyone really successfully used an Easy-Out? Please exclude the ones you heard about from a friend who heard it from their cousin who heard it from ... Thanks! If I knew how to quote by pushing buttons, I would but I don't so here it is the old fashioned way: FrankenMech "Removing broken fasteners is an essential skill for working on scooters." Maybe that's a chapter title for the Essential Scooter Book? I tried an extractor screw on a screw of a carburtor and on a screw of the blue wire, in order to bridle the scooter, from the clutch assembly to the cdi, and it fails both times. The part of the extractor to remove the crew just drills, like the part of the extractor which drills. Perhaps those extractors works when the screw is not tighten with an impact driver.
Post by floyd2133 on Aug 14, 2017 16:27:36 GMT -5
Has anyone really successfully used an Easy-Out? Please exclude the ones you heard about from a friend who heard it from their cousin who heard it from ... Thanks! If I knew how to quote by pushing buttons, I would but I don't so here it is the old fashioned way: FrankenMech "Removing broken fasteners is an essential skill for working on scooters." Maybe that's a chapter title for the Essential Scooter Book? I tried an extractor screw on a screw of a carburtor and on a screw of the blue wire, in order to bridle the scooter, from the clutch assembly to the cdi, and it fails both times. The part of the extractor to remove the crew just drills, like the part of the extractor which drills. Perhaps those extractors works when the screw is not tighten with an impact driver. I took dremmel back and bought this ... I'm headed to the scoot as we speak I will take a pic and record video thanks for all the input
Post by lostforawhile on Aug 14, 2017 17:31:14 GMT -5
best of luck hanson stuff is brittle and snaps, I use their taps sometimes for really small stuff, but they tend to snap too.
Post by floyd2133 on Aug 14, 2017 19:05:06 GMT -5
best of luck hanson stuff is brittle and snaps, I use their taps sometimes for really small stuff, but they tend to snap too. It snapped I been working on this for 6 months so what's my next option It did not work in upset
Post by lostforawhile on Aug 14, 2017 19:12:18 GMT -5
is the hole on center?? that's critical as you can keep drilling out the broken bolt with bigger and bigger bits, until its weak enough to shred out.but you haeto make sure you don't go too deep,but I cant remember, but doesn't that hole go all the way through?
Post by lostforawhile on Aug 14, 2017 19:14:55 GMT -5
the easy out snapped? if it did, you need to do a bunch of disassembly and take the part to a shop with a tap disintegration machine where they use an arc to burn it out
Post by FrankenMech on Aug 15, 2017 1:04:11 GMT -5
There is hard metal down in that hole. Your next option is taking it apart and taking the case to a shop with an EDM machine.
Post by lostforawhile on Aug 15, 2017 6:35:06 GMT -5
There is hard metal down in that hole. Your next option is taking it apart and taking the case to a shop with an EDM machine. it might be able to be removed with a pencil grinder and a bunch of diamond bits, or drilling around it, but that takes skill and patience, and you had better know what you are doing, that cheap easy out, just made the job 10 times harder
Kick start
Aug 15, 2017 19:22:08 GMT -5
via mobile
Post by catchacuda on Aug 15, 2017 19:22:08 GMT -5
Know anybody near you that is handy with a MIG? Weld a nut through it's center onto that broken fastener. The heat will help a lot, a turn of the welded nut and it should come right out.
Post by lostforawhile on Aug 15, 2017 20:16:49 GMT -5
Know anybody near you that is handy with a MIG? Weld a nut through it's center onto that broken fastener. The heat will help a lot, a turn of the welded nut and it should come right out. hope it sticks to that easy out, best of luck
Kick start
Aug 15, 2017 20:20:20 GMT -5
via mobile
Post by catchacuda on Aug 15, 2017 20:20:20 GMT -5
I know it doesnt sound too promising, this is exactly what I did in a turbine housing. I snapped the bolt, then snapped an easy out in it. It got it out. Maybe just luck
Post by floyd2133 on Aug 17, 2017 15:13:14 GMT -5
I know it doesnt sound too promising, this is exactly what I did in a turbine housing. I snapped the bolt, then snapped an easy out in it. It got it out. Maybe just luck What size easy out should I use ? Should I keep drilling until it HOPEFULLY sticks? Can I use a easy out with a drill?
Kick start
Aug 17, 2017 17:36:39 GMT -5
via mobile
Post by catchacuda on Aug 17, 2017 17:36:39 GMT -5
I've never had luck with easy outs. I would try the welding a nut method, short of taking it to a machine shop.
Post by floyd2133 on Aug 19, 2017 13:54:51 GMT -5
I got it out with titanium bits n a easy out 6 months of no riding I'm back bitches
