Post by floyd2133 on Aug 4, 2017 18:30:24 GMT -5
Hey I'm tired of striping my kick start lever with these after market kick starts . My scoot only starts by the kicker and is a short case I want a dirt bike type kicker with the right specs and threads to fit My TAO TAO 50cc .......10 dollars each time and a wait of two weeks just 🏎💨 my heart.
Post by FrankenMech on Aug 4, 2017 21:56:18 GMT -5
Get the electric start working.
Post by floyd2133 on Aug 4, 2017 21:59:12 GMT -5
Get the electric start working. The starter screw is broke into the frame and I have to remove engine to get it out and create new threads.
Post by lostforawhile on Aug 4, 2017 23:08:45 GMT -5
you cant access the screw from the side?
Post by dan50 on Aug 5, 2017 0:38:13 GMT -5
One thing that helps to not break kick starts on scooters is move the lever so it is in the 1:00 position instead of the 3:00 position.
Post by floyd2133 on Aug 5, 2017 3:13:36 GMT -5
you cant access the screw from the side? No the screw to hold starter broke off into the engine casing half and half flush on surface
Post by FrankenMech on Aug 5, 2017 4:14:42 GMT -5
Slot the screw with a dremel and thread it out. Removing broken fasteners is an essential skill for working on scoots.
When replacing fasteners always use anti-seize on steel fasteners threaded into aluminum.
Post by floyd2133 on Aug 5, 2017 7:17:01 GMT -5
Slot the screw with a dremel and thread it out. Removing broken fasteners is an essential skill for working on scoots. When replacing fasteners always use anti-seize on steel fasteners threaded into aluminum. Is there a video on this? And I'm referring to the BOLT not a Fastener?
Post by lostforawhile on Aug 5, 2017 7:42:17 GMT -5
Slot the screw with a dremel and thread it out. Removing broken fasteners is an essential skill for working on scoots. When replacing fasteners always use anti-seize on steel fasteners threaded into aluminum. Is there a video on this? And I'm referring to the BOLT not a Fastener? um, a bolt is a fastener,
Post by floyd2133 on Aug 5, 2017 7:43:25 GMT -5
Is there a video on this? And I'm referring to the BOLT not a Fastener? um, a bolt is a fastener, lol ok thanks but if there was a video maybe I can reference that
Post by lostforawhile on Aug 5, 2017 7:50:26 GMT -5
please get a good picture of the broken bolt, so we can see what you are working with, and try not to piss off the mechanical Gods by using an easy out, which will only result, in a broken bolt,with a super hard broken easy out, broken in it, which is nearly impossible to remove
Post by Cincikid on Aug 5, 2017 14:34:20 GMT -5
Seems like fixing that e-start will save you some headaches.
A less expensive Dremel(off brand) will work also. Check reviews.
Post by FrankenMech on Aug 5, 2017 19:42:04 GMT -5
A dremel type tool is one of the 'essential' power tools.
A person can never have too many tools. They say even Easy-outs can have their uses when used very carefully.
Post by lostforawhile on Aug 5, 2017 21:36:06 GMT -5
A dremel type tool is one of the 'essential' power tools. A person can never have too many tools. They say even Easy-outs can have their uses when used very carefully. yes, their primary purpose is to make machinists lots of money, and to keep the EDM machine people in business
Post by floyd2133 on Aug 5, 2017 21:37:49 GMT -5
Well any suggestion wee I can go in ga
