Post by highmoose on Dec 13, 2014 0:54:30 GMT -5
top on are the carb the bottom ones are the shiney cool looking but cheaply made air filter intake
Post by Clank on Dec 13, 2014 5:48:15 GMT -5
I'd say go with a 38 pilot jet and try a 85 or 90 with a bbk. See if anyone else posts with a different opinion. Each scooter for one reason or another seem to be temperamental like my better half. Be fine one week with with the blue shoes the next wants to kill me for buying them. :2cents:
Post by highmoose on Dec 19, 2014 23:45:13 GMT -5
so i was looking at kick start gears and im not sure wich one to buy. do i hvae to go and take it off and look at it. cuz i see sum with 8 splines and i see some woth a silver cylinder with gears or the gears with the locking washer?? please help
Post by highmoose on Dec 20, 2014 11:20:58 GMT -5
Post by niz76 on Dec 20, 2014 11:30:05 GMT -5
If they're led- looks like they are- you may experience "hyper flashing" as the leds load is considerably less than the edison bulbs. They sell an led blinker relay somewhere but I'd imagine you'd have to change all blinkers over to led. They also sell a big fat resistor that mimics the load of original bulbs so you can use your stock relay without the hyper flashing syndrome. Sorry I don't have any links for any of this stuff But yes- they wire into your current blinker wires. Leds are polarity sensitive (they won't work if you have the + and - wrong) so you'll need to know which wire is + and which -.
Post by highmoose on Dec 20, 2014 12:38:56 GMT -5
will the hyper flashing harm blinkers or burn them out or burn up wiring?
Post by Elektrey on Dec 20, 2014 12:44:04 GMT -5
don't think so, it will just flash more often.
Post by highmoose on Dec 20, 2014 12:46:21 GMT -5
can deal with that im goin to buy to replace all four blinkers ty for the help
Post by highmoose on Dec 20, 2014 15:43:32 GMT -5
also have to get the gears for the kick start i have looked at the videos and alot of posts i dont see any one talking abut the difference of 7 teeth and 8 teeth. can i use either or specificaly one. or is one better then the other?....forget it looked and its a 8 tooth so just got the same.
hgoodloe25
Where's the nearest to me scooter gatherings in Virginia?
Post by hgoodloe25 on Dec 22, 2014 14:53:40 GMT -5
I used a regular cell phone holder from Walmart, My speedo isn't working properly so I started using all GPS and I took the phone holder drilled out holes to fit screws down through it and went put it through right above me speedo to hang over where my speedometer is and I can still see my gas gauge and all.
Post by Elektrey on Dec 22, 2014 16:08:46 GMT -5
pics !
Post by maddogtannen on Dec 31, 2014 14:30:25 GMT -5
Just found this thread. Great info on here, as I have the same bike and am planning a BBK soon. I sent you a PM before I saw this thread, you can ignore it as most of my questions were answered reading through here.
So the 64mm valve head you got was correct for your engine? I have a 64 mm valve 100cc BBK, but it doesn't come with the cam or rocker assembly. So I would be using the 64mm valve head with stock cam and rockers. I want to make sure that I dont need the 69mm valve head before I rip my motor apart.
Post by highmoose on Jan 2, 2015 16:23:08 GMT -5
I'd say if your gonna do it do it rite.might as well get it to run better.
Post by maddogtannen on Jan 5, 2015 10:35:12 GMT -5
Mine runs great as is, but I'm hoping for a few more mph out of it. I did some research and it looks like the valve lengths are 64mm, for future reference.
Post by highmoose on Jan 8, 2015 1:09:48 GMT -5
Awsome Ty , gonna replace kickstart gearing maybe tomorrow and my turn signals should b in any day. It's really -10 degrees out ... Wonder how much is have to bundle up for a lil Cruz wen done
