Post by Jwhood on Nov 2, 2014 19:43:26 GMT -5
Yeah r.p is a big :thumbdown:
Post by katastroff on Nov 2, 2014 20:04:34 GMT -5
Have you looked up Motoforce shocks? Shock absorber Motoforce ST1 (245mm)
I'm not into pushing parts, but scootertuning has it for $26. With the promo code it would be around $40 to your door.
Post by 90GTVert on Nov 2, 2014 20:05:51 GMT -5
I bought the YSS shock for T1 from Dennis Kirk so you could try checking there.
Post by 2TDave on Nov 2, 2014 20:30:40 GMT -5
I'll check Dennis Kirk. I got a pretty good deal on tires from them. The motoforce looks like a stock Triton shock. I think a lot of their stuff is comparable to stock parts. Don't know about their cranks or cylinders but the intake I got was a match to stock, same with their air box. Not that any if it is bad but those shocks can be had for less.
Post by nelson on Nov 2, 2014 22:38:44 GMT -5
Cant wait to see/ hear this baby run!
Post by katastroff on Nov 3, 2014 7:12:19 GMT -5
I'll check Dennis Kirk. I got a pretty good deal on tires from them. The motoforce looks like a stock Triton shock. I think a lot of their stuff is comparable to stock parts. Don't know about their cranks or cylinders but the intake I got was a match to stock, same with their air box. Not that any if it is bad but those shocks can be had for less. That's about what they are, replacement part with a brand name. Most stuff up here always sells for more then in the US. Must be related to the length of the riding season.
Post by 2TDave on Nov 3, 2014 7:44:39 GMT -5
I hope to have somethings here this weekend to get it fired up and do some testing.
Post by nelson on Nov 3, 2014 10:16:19 GMT -5
I have a short shock laying around. Let me know if you are interested. Just have short stock and aftermarket the aftermarket came from Hawaii so has small rust spots but u pay shipping its yours. Or if u just need a short stock shock I got one, just to get you going
Post by nelson on Nov 3, 2014 10:20:21 GMT -5
Post by 2TDave on Nov 3, 2014 10:35:06 GMT -5
Thanks Nelson. I've got the stocker on now and will run with that until I get the other stuff worked out.
Post by 2TDave on Nov 3, 2014 18:20:16 GMT -5
Post by moofus02 on Nov 3, 2014 18:32:16 GMT -5
Thank god cast iron kits are tough
Post by jhobe6678 on Nov 3, 2014 18:47:38 GMT -5
A little windex and that baby will be like new! Seriously, I'm glad my 2t is cast iron after seeing this. But my god man.
Post by 2TDave on Nov 3, 2014 18:47:39 GMT -5
Yep. But there's plenty of oil in the cylinder and I was working my way down from stalling pig rich so I'm not sure what caused it.
Post by 190mech on Nov 3, 2014 19:55:46 GMT -5
Might have too tight a piston to bore fit..Once you clean it up,it should be OK..
