Post by Grom Reaper on Mar 24, 2015 17:24:46 GMT -5
Haha I couldn't agree more! Bowtie for life! But for now these are the only ones I've found that'll swap pretty easily. Even a "dead" coil that won't run a ford or one that'll still set codes will STILL run a scooter, I've tested it just to see.
Post by Mrx2002 on Mar 24, 2015 18:21:16 GMT -5
Haha now it begins. All I gotta say i have an 87 Ford Ranger with over 1.2 million mles on it still runs great and my scoots fit in the back. But really though any parts are better than what's on our scoots now!
Post by runningbuck on Mar 24, 2015 21:11:43 GMT -5
I would rather use a ford part than try to get the squirrels to run faster LOL
Post by craisin on Mar 25, 2015 22:13:20 GMT -5
Our China scooters are kinda challenged on the dependability area , but putting ford parts on our scoots is asking for trouble. ok ford guys let me have it bend over
Post by TheAmishSasquatch on Apr 15, 2015 16:35:02 GMT -5
If a proper DIY were made' I'd try this out.
Post by Sitticuss on Apr 15, 2015 18:11:42 GMT -5
I file this whole idea into the "sugar pill" folder.
Post by Grom Reaper on Apr 15, 2015 20:10:44 GMT -5
I file this whole idea into the "sugar pill" folder. Hahaha. Is that so? I think you may need to do a little research there bud. Just because you don't understand or are incapable of performing this type of modification doesn't mean you gotta knock it. And I'll try to make a DIY for this sometime this weekend Amishsasquatch. Just hard to find the time. It really is a simple mod if you've got access to the necessary tools.
Post by Sitticuss on Apr 15, 2015 20:17:11 GMT -5
I file this whole idea into the "sugar pill" folder. Hahaha. Is that so? I think you may need to do a little research there bud. Just because you don't understand or are incapable of performing this type of modification doesn't mean you gotta knock it. And I'll try to make a DIY for this sometime this weekend Amishsasquatch. Just hard to find the time. It really is a simple mod if you've got access to the necessary tools. I'll slap another coil on my car and get back to you. Should be awesome with a dual coil setup. Take your pills everything will be fine. I've got a fan you can stick on your intake it swirls the air like a Tornado and increases your horse power and fuel efficiency by up to 25%....lol
Post by dray492 on Apr 16, 2015 3:17:36 GMT -5
I did this today, i dont know if it made a difference though because i changed the plug and gear oil at the same time. Very easy mod. Step 1: go to junk yard. Step 2: find any v8 ford from 00' up, (its easier if you find one with the head pulled already. I happened to find (i think it was a merc) sedan with a pulled head and all the coils in a pile. Cut a good bit of the wire off so you have room to find a good mounting point. Step 3: cut the spring and rubber boot just below the metal rod in the middle. Step 4: remove old plug wire and wire up the cop. In my case the green wire with a white/silver stripe was the power and the red was ground. I used a male connector thing from autozone and it hook right up to stock wiring. I grounded at the stock ground as well. Step 5: secure it whatever way works best for your setup. I used zipties.
Thats it. Simple.
Post by Grom Reaper on Apr 16, 2015 7:50:17 GMT -5
Lol. Right so back to topic. Yeah it's an easy mod. The biggest difference i saw was on start up. And I'm sure the engineers who design our cars nowadays are much smarter than most of us and I'm quite sure there's a great reason they did away with plug wires and went to c.o.p. ignition. Enough said. Oh and two coils per cylinder? Huh? That's just silly.
Post by 90GTVert on Apr 16, 2015 7:51:23 GMT -5
I don't see every ignition mod as a placebo/sugar pill, but many don't do what's claimed. Never beleive it if someone tells you a coil will give you 10MPH for example. If you have a problem with a weak spark, increasing the spark intensity will help, possibly a lot. If your current spark is igniting the mixture consistently, don't expect to notice much change. One place that it seems most obvious from my experience is cold starting. When conditions aren't ideal a better spark can make quite a difference.
Post by humanshield on Apr 16, 2015 7:53:51 GMT -5
Our China scooters are kinda challenged on the dependability area , but putting ford parts on our scoots is asking for trouble. ok ford guys let me have it NO YOU DIDNT !
Post by Sitticuss on Apr 16, 2015 17:57:28 GMT -5
Lol. Right so back to topic. Yeah it's an easy mod. The biggest difference i saw was on start up. And I'm sure the engineers who design our cars nowadays are much smarter than most of us and I'm quite sure there's a great reason they did away with plug wires and went to c.o.p. ignition. Enough said. Oh and two coils per cylinder? Huh? That's just silly. Yeah the secret reason is.....It's cheaper......Please stop enabling me...I'm totally dain bramaged and can't help myself. You? Enough said. I've seen that mod with a triple ground electrode spark plug also. Whatever floats your boat.
Post by TurboTyler on Apr 22, 2015 1:13:46 GMT -5
I actually run the NCY COP on my 150. It did help with throttle response by about 15 percent. Other than that it burns more gas and granted a smidgen more power but no top speed. The bracket it came with is worthless. I tried this on my 49cc and it didn't do shit to it. That is why NCY doesn't make one for 49cc. It's a complete waste of money and some because there isn't enough power to make power lol.
Post by joeorange on May 11, 2015 12:10:29 GMT -5
i have a couple of "bad" coils from a 2003 ford escape, if they will work ill use them for my GY6 swap. id use it on the 1e40qmb that is currently in the scooter but i lack the incentive to put it on at this moment.
