Post by bugboy1641 on Jul 2, 2015 3:13:16 GMT -5
Hope you don't mind me asking but the COP mod sounds intriguing.
I've got a few COP's floating around from a Peugeot V6 engine. These are 2 pin coils but they are supplied with a constant 12v and are earth switched by the Engine ECU.
Can someone let me know if the Ford coil works the same way or vice versa?? I'd also like to understand how a typical scoot coil is energised and operated if possible?
I'm trying for every conceivable budget mod on my stock minarelli 50. Any help would be appreciated!
Post by TheAmishSasquatch on Jul 4, 2015 8:01:15 GMT -5
Since Im a dub and Euro guy, I reccon Ill go source a coil pack from a VR6 or something and give it a go. Im still thinking about the MSD coil Brent is running.
Post by cwazywazy on Mar 14, 2016 19:54:41 GMT -5
Sorry for the bump, but which pin is which and will it work with my AC CDI?
Post by TheAmishSasquatch on Mar 15, 2016 17:47:42 GMT -5
It's pretty self explanatory once you physically have the components on hand. IIRCC there was a brownish-red (hot wire) and a white/black (ground wire) on the one I snagged. My scoots wiring harness & terminals for the coil are black/yellow (hot) green (ground). So just hook em up and done.
Post by cwazywazy on Mar 15, 2016 18:21:48 GMT -5
It's pretty self explanatory once you physically have the components on hand. IIRCC there was a brownish-red (hot wire) and a white/black (ground wire) on the one I snagged. My scoots wiring harness & terminals for the coil are black/yellow (hot) green (ground). So just hook em up and done. Yeah, but it's not OEM and there's no wires that came with it. Does it hurt anything if I just plug it in randomly and see if it works?
Post by TheAmishSasquatch on Mar 15, 2016 20:03:25 GMT -5
Best thing to do would be go to a junk yard and find a Lincoln or Focus with that style coil pack and clip the male side pig tail and go from there. I took the COP and it's immediately pigtail/harness. After I modded the plug lead portion and added a Bosch connector, I just lengthened the pigtail harness and added spade connector to the new wires. Plug n play at that point.
Post by niz76 on Mar 15, 2016 21:42:36 GMT -5
Sorry for the bump, but which pin is which and will it work with my AC CDI? I've flipped the wires on coils before with no ill effect when trying to find the right combo. Just the typical 2t/GY6 scoot coils....
Post by Grom Reaper on Apr 8, 2016 14:44:28 GMT -5
Sorry for the long time lapse lol. There is a definite power and ground pin. On the 2 pin ford coils there is a tiny TINY + symbol for the power pin.
Post by TheAmishSasquatch on Apr 9, 2016 9:12:43 GMT -5
After trying the COP a couple times, I'm still on the fence. I know the Ford COP draws more current when using the electric start. After a few tries, if the bike doesn't fire, the batt is dead. Even quicker then normal.
Post by Grom Reaper on Apr 9, 2016 20:36:52 GMT -5
Hmmm. I haven't experienced that issue with them yet. Gen 1 or 2 coils?
gmc
Scoot Junior
Post by gmc on Aug 27, 2016 15:03:16 GMT -5
Coil on plug works better because of the loss through the spark plug wires. Graphite wires were invented because of electromagnetic interference when used with sensitive electronics. A scooter doesn't have the electronics that a car has. I suggest a new Ford coil because I have tested them for racing applications. The spark is hotter and it helps with misfires. Misfires occur mostly at low rpms. That is why they start a vehicle easier. Ford went over to them to meet the emission standards (so did all car companies). The motor does not run hotter because of it. A vehicle can misfire 10% of the time at low Rpms.
Post by wutno on Sept 6, 2016 13:43:52 GMT -5
Basically get a crown vic 2 wire coil and hook it up?
Post by honda4life on Sept 13, 2017 23:10:18 GMT -5
Hmmm, just ordered mine off of fee-bay
Post by AtariGuy on Sept 14, 2017 20:57:21 GMT -5
Hmmm, just ordered mine off of fee-bay pictures! Or it didn't happen lol (wink) No really tho, sounds interesting, might have to go clip a cop off my parts truck and try it myself
Post by honda4life on Sept 14, 2017 21:49:01 GMT -5
Yeah, I paid $8 for the 2 wire plugs and $12 for two c.o.p. coils with plug boots. $20 does both my scoots. Sounds promising. Wth
