Post by Sitticuss on Apr 7, 2015 10:38:56 GMT -5
Are you sure there is no spark? Did you wet your pinky finger and insert it in the spark plug boot while cranking it.... ::zap:: Yes, no spark whatsoever. I used a spaark plug boot tester to see if there was a spark @90gtvert, I will check them when I get home from work. They make a boot tester? Wow you learn something new everyday. I bet you knocked a wire loose like Brent said. Don't forget to check the fuse etc also.
Post by thatcrazyguy on Apr 7, 2015 11:18:11 GMT -5
Checked both fuses, my batteries been dead for like 2 weeks or so, gonna try to make it to store today to buy another for easier diagnosis! But still, kick starting scoot is not producing a spark.
Post by niz76 on Apr 7, 2015 12:52:54 GMT -5
Maybe you removed the ground wire to engine while taking CVT cover off or something? There's often a heavy engine ground wire that is bolted on with one of the CVT cover bolts...
Post by thatcrazyguy on Apr 7, 2015 13:19:01 GMT -5
Maybe you removed the ground wire to engine while taking CVT cover off or something? There's often a heavy engine ground wire that is bolted on with one of the CVT cover bolts... I always make sure that I ground that wire back out. Im gonna go home today and check every damn wire and make sure there all connected. I tried taking a screwdriver and try to turn the starter using the solenoid, and nothing. Shouldnt that usually bypass the dead battery and get the engine to turn?
Post by niz76 on Apr 7, 2015 14:47:31 GMT -5
If the battery is dead, the starter isn't going to turn... also isn't included in the circuit that produces spark...
Post by thatcrazyguy on Apr 7, 2015 15:32:42 GMT -5
Is there a map of cirtuits somewhere here
Post by niz76 on Apr 7, 2015 15:49:45 GMT -5
Post by niz76 on Apr 7, 2015 15:53:38 GMT -5
If u get too frustrated I have extra of everything to pinpoint your no-spark issue- happy to help out a member get scootin again!
Post by thatcrazyguy on Apr 7, 2015 16:01:18 GMT -5
If u get too frustrated I have extra of everything to pinpoint your no-spark issue- happy to help out a member get scootin again! Thanks man, I ordered a new cdi, and a tach for when I get it running. I checked every single wire and there all plugged into something. I had an oil leak, and the wire connections from the stator to the wiring harness are oily. Gonna clean em tomorrow, done for today.
Post by thatcrazyguy on Apr 8, 2015 7:43:23 GMT -5
Gonna check the local scoot shops in my area to see if they have any cheap stators, if not ill be getting one from niz76, also going to install the voltage regulator and hopefully this scoot will be up and running by the end of the day!!! Im ready and itching like hell to get back on 2 wheels. I wish I never bought a car and bought a 2nd scoot lol
Post by thatcrazyguy on Apr 8, 2015 15:51:04 GMT -5
Figured out today it came down to either my ignition went bad or stator. I ordered the stator for now since I just replaced my ignition like 6months ago. Purchases a battery today, just gotta charge it. And purchased a stator, flywheel puller, and an adjustable 280mm rear shock from partsforscooters. Should have them tomorrow or friday.
Post by thatcrazyguy on Apr 8, 2015 21:47:41 GMT -5
Gonna have a fun day tomorrow getting new parts installed!! Can't wait to get the stator in, and praying it is what isnt producing the spark, praying!!!
Post by thatcrazyguy on Apr 9, 2015 8:38:38 GMT -5
All parts I ordered will be at my house by the time I get home from work, and starting to install and hopefully have it running within 2 hrs and be on the road again!! Will upload some pics tonight as well.
Post by thatcrazyguy on Apr 9, 2015 15:28:27 GMT -5
Parts are at the fedex facility, going to pick them up after 6pm. In the meantime I spray painted what plastic panels I am keeping on the scoot, flat black. Rims will be another day, possibly another color. Pictures tonight, or tomorrow, whenever its back together:D
Post by thatcrazyguy on Apr 11, 2015 16:49:44 GMT -5
And shes alive again!!! A bit of playing with cdi's, wires, and installing the new stator, shes alive once again. Just have to upjet a bit more than I did, scoots starvin for fuel and not going fast at WOT.
