Post by thatcrazyguy on Apr 26, 2015 0:15:51 GMT -5
Crazyguy came to my house today on his scoot and wow gotta say he is really living up to his forum name haha. He drove his scoot all the way from Clearwater (maybe 30 miles down a super busy 4 lane road US19) pulling on a string attached to his throttle cable! LMAO Scoot seemed to be running pretty well but that string- yeah Crazy! Haha, gotta get around!! Gonna order a new cable monday morning thanks for the piston and front turn signal my friend.
Post by thatcrazyguy on Apr 26, 2015 15:01:30 GMT -5
Post by 2TDave on Apr 26, 2015 16:51:29 GMT -5
I haven't installed one on a Zip. It was pretty straightforward on my RX8/Triton.
Post by thatcrazyguy on Apr 27, 2015 8:57:57 GMT -5
So im looking into a performance cvt kit, I may get just a new variator and lighten the clutch, but whats the difference in the stock and performance variators?
Post by niz76 on Apr 27, 2015 11:47:57 GMT -5
Post by thatcrazyguy on Apr 27, 2015 19:30:41 GMT -5
Got the new bbk installed on the zip r3i, didnt have my jet kit to upjet, and she soft seized, didnt feel like ruining the cylinder or piston, so Im leaving it sit until tomorrow when my dad drops it off at my house, its in his garage about 15miles away.
Post by thatcrazyguy on Apr 27, 2015 21:55:37 GMT -5
Post by thatcrazyguy on Apr 28, 2015 9:27:54 GMT -5
Couple questions I have about soft seizing..
Can low compression cause soft seize? Can not upjetting after install of bbk cause it?
Post by 2TDave on Apr 28, 2015 11:47:10 GMT -5
Never heard of low compression causing a seize but improper jetting certainly will.
Post by thatcrazyguy on Apr 28, 2015 11:50:59 GMT -5
Never heard of low compression causing a seize but improper jetting certainly will. Ok, my compression was about 90 before I fired her up, what should it be? And ill re jet before I start her up and change the throttle cable
Post by thatcrazyguy on Apr 28, 2015 11:53:06 GMT -5
Let me know if im wrong, so too small of a jey, and lack of oil is what I need to focus my attention on as my problem?
Can I run the scoot with premix and disassemble the oil pump cable thats attached to the throttle cable? Thats what I did when I took it on a test run. my throttle rig was also stuck at full throttle so I couldnt go anyslower besides holdin back brake to restrict revs
Post by iwiketuddlz on Apr 28, 2015 13:57:44 GMT -5
I have a new oem throttle cable for you to replace the stock double cable If your ditching the pump... $10 plus shipping if interested...
Post by thatcrazyguy on Apr 28, 2015 15:35:58 GMT -5
I have a new oem throttle cable for you to replace the stock double cable If your ditching the pump... $10 plus shipping if interested... Does it have the 90° angle on both sides? I dont ever mind having extra parts lol
Post by thatcrazyguy on Apr 29, 2015 21:54:12 GMT -5
So I really like the triton r4 front panel better than the zip, will they fit properly with the rest of the zip panels?
Post by thatcrazyguy on Apr 29, 2015 22:03:10 GMT -5
Also, any guide on here that shows how to vent the cvt case? I put 5 3/8" holes together, but would like to know what tools etc to open it up all the way!
