Post by thatcrazyguy on Oct 18, 2015 21:22:52 GMT -5
I have racked up a lot of miles mixing at 45:1 with the Quicksilver Walmart oil... (I add 3 0z. to each gallon of fuel.) I'll check it out next time I'm there!! I'll have to come up and see ya soon! Go for a ride together before it gets too cold, haha
Post by thatcrazyguy on Oct 19, 2015 12:50:51 GMT -5
Gonna start breaking into the electrical connections to the headlights and battery connections, starter connections and the electric start button, sand that down and all grounds! This should be fun!! I hate electrical issues Also I have a question, I am not running any front brakes right now, and I bought both left and right brake and instrument things but the front brake lever is setup for drum, not hydraulic which is what I have, can I throw the rear brake line in on the right side if I have slack and what do I do with the front brakes? Just remove the line or the whole caliper and all?
Post by thatcrazyguy on Oct 19, 2015 14:39:13 GMT -5
I ended up removing everything that involved front brakes for now! I need to find new front brake caliper. I also went over everything electrical, everything was plugged in properly, except for the voltage regulator. I followed Brent's guide to re-wiring it and it ended up not holding up very well so I re-wired it again and seems put together pretty well this time. Next is charging my battery, Advance trickle charged it over after testing the battery, condition is good and voltage was 12.36. I go yesterday mornin to pick it up, have them re-test it and the battery read 12.15..... How can it lose voltage after charging all night? Should I go ahead and just buy a new battery or should I charge this one again and see if it gets any better??
Post by iwiketuddlz on Oct 19, 2015 14:47:27 GMT -5
12.3 is a dead battery!!! It need 12.5VDC or more!!!
Post by thatcrazyguy on Oct 19, 2015 14:51:19 GMT -5
12.3 is a dead battery!!! It need 12.5VDC or more!!! I know, it was 12.3 before sitting on the trickle charge all night and then next morning after pulling it off it was 12.15!!!!!!!!! How in the hell.....
Post by iwiketuddlz on Oct 19, 2015 14:53:43 GMT -5
Mmm?? What tha!!!! I dunno bout that one good sir!!but for a reference mine usually stay around 12.7VDC
Post by thatcrazyguy on Oct 19, 2015 14:54:19 GMT -5
Mmm?? What tha!!!! I dunno bout that one good sir!! Hahaha I don't either!!!!!!
Post by thatcrazyguy on Oct 20, 2015 12:06:02 GMT -5
So I have my cart ready to order from PartsForScooters.com, all I need to do is measure my kick start shaft and then I won't have to worry about my electric start problem. I do plan on removing engine before the end of the month and swapping out starters and then worry about a new battery if I can't get mine to charge.
Post by iwiketuddlz on Oct 20, 2015 13:37:15 GMT -5
Dude I have an cracked longcase cvt cover....complete if ya want it..
Post by thatcrazyguy on Oct 20, 2015 14:37:26 GMT -5
Dude I have an cracked longcase cvt cover....complete if ya want it.. I have a shortcase cover, the kickstart shaft is 73mm
Post by iwiketuddlz on Oct 20, 2015 15:08:47 GMT -5
Heck I bet it's the same?! I'll check when I get home bro .. No worries
EZ pee z
Post by thatcrazyguy on Oct 20, 2015 15:10:04 GMT -5
Heck I bet it's the same?! I'll check when I get home bro .. No worries EZ pee z Thanks man, just tore out my engine to possibly clean it and maybe paint it glossy black??? and also swap starters
Post by thatcrazyguy on Oct 20, 2015 15:33:59 GMT -5
Heck I bet it's the same?! I'll check when I get home bro .. No worries EZ pee z Thanks tuddlez, but I'm just gonna go ahead and order a new one. Gonna get this order in and have it shipped out today hopefully
Post by iwiketuddlz on Oct 20, 2015 15:38:06 GMT -5
Cool deal bro Happy scooting !!!! They have super fast shipping too
Post by thatcrazyguy on Oct 20, 2015 16:57:05 GMT -5
Cool deal bro Happy scooting !!!! They have super fast shipping too Ok I lied man, wasn't able to get the order in before they closed, can you pls check the size of your kick start shaft need 73mm tybro
