Post by thatcrazyguy on May 16, 2015 8:21:47 GMT -5
Threw my old cylinder on yesterday, this cylinder will run at full throttle with a slight bog, wonder If its just the elcheapo bbk thats not runnin right?
Post by Elektrey on May 16, 2015 10:20:11 GMT -5
change jetting?
Post by thatcrazyguy on May 16, 2015 11:38:11 GMT -5
All I have is 75-115(multiples of 5) and 85 is the best, also changed the needle setting and middle is best. Best in this situation means it runs. Every other setting would not throttle up
Post by thatcrazyguy on May 17, 2015 13:13:11 GMT -5
Post by thatcrazyguy on May 19, 2015 16:00:35 GMT -5
Got an email today from racingplanet has shipped my tail light. Once I get it, hopefully tomorrow, ill install that, install the original headlight assembly, and rip out the oil tank while I have the scooter apart, not sure if ill be able to the flywheel off to remove the pump, but well see.
Post by thatcrazyguy on May 19, 2015 16:20:59 GMT -5
Post by thatcrazyguy on May 21, 2015 8:52:54 GMT -5
Been tracking the tail light, should be delivered today!!! Also borrowed my dads electric impact to get the clutch off! Hopefully I can get the pulley nut off to change out torque spring and clutch springs as well. Have 2k clutch ans 1.5k torque springs, hopefully ill be able to pull wheelies
Post by thatcrazyguy on May 21, 2015 12:57:11 GMT -5
Tail lights been delivered, not sure what im gonna get done on the scooter today, have to stop by amscot to pay bills and grab a money order and start laundry, tail light will probably wait until tomorrow as ive gotta get mounting brackets
Post by thatcrazyguy on May 21, 2015 18:36:08 GMT -5
Well I got the clutch off, but I dont have a vice and big enough wrench or 1.5 in impact socket. Im gonna try to take it apart tomorrow after work at my bosses house, well see. And I got the L mounting brackets for the light. So ill try n get that installed tomorrow as well.
Ive had an electric issue, this zip r3i had a bad voltage regulator, I replaced it and all light bulbs and they were working. Recently I realized my electric start wasnt working and the lights, I checked fuse but it was not broken, hut I replaced anyways, still no electric. Even with the scooter running I have no lights, what could it be?
Post by niz76 on May 21, 2015 19:08:01 GMT -5
Yo Scott I'm back home and the garage door is open again if u need anything!
Post by 90GTVert on May 21, 2015 19:18:36 GMT -5
Are all of your grounds hooked up? Ignition switch working (should see power in and out when on)?
Post by thatcrazyguy on May 21, 2015 19:19:21 GMT -5
Yo Scott I'm back home and the garage door is open again if u need anything! Ahhh okay bud, not sure when I can make it up there, ill see if I can leave work early tomorrow, let you know before 12! Can anyone answer my electrical issue
Post by thatcrazyguy on May 22, 2015 20:29:18 GMT -5
Are all of your grounds hooked up? Ignition switch working (should see power in and out when on)? All grounds connected, yes. The bigger of the 2 square black box, one is the cdi the other is somethinf else not sure, I know if its unhooked you can kick start without key, sorry for bad explanation but I figured someone would know what im talking about, that has not been in the scoot since I bought it, could that be the issue?
Post by 90GTVert on May 23, 2015 6:46:18 GMT -5
The alarm? Lights and whatnot should still work, just causes some issues with using switches to kill the engine usually : 49ccscoot.proboards.com/thread/386/remove-alarmI'd be checking the ignition switch. I think the wires will be red and red/white, but maybe not. One should have power from the batt full time. One should have power when the switch is on and none when it's off.
Post by thatcrazyguy on May 23, 2015 7:26:23 GMT -5
The alarm? Lights and whatnot should still work, just causes some issues with using switches to kill the engine usually : 49ccscoot.proboards.com/thread/386/remove-alarmI'd be checking the ignition switch. I think the wires will be red and red/white, but maybe not. One should have power from the batt full time. One should have power when the switch is on and none when it's off. I plugged th alarm in, no difference. Ill check ignition wires when I swap headlight assemblys. Thank Brent
