Post by 808ministroke on Dec 1, 2020 0:36:28 GMT -5
i have this delta clutch on my piaggio came from previous owner . is mine adjustable like thay aswell? with weights and varying amounts of preload?
Post by mauibird on Dec 1, 2020 20:05:12 GMT -5
i have this delta clutch on my piaggio came from previous owner . is mine adjustable like thay aswell? with weights and varying amounts of preload? No, mine is the delta clutch
Post by mauibird on Dec 1, 2020 20:10:30 GMT -5
Trying to make the Polini air box fit
Post by mauibird on Dec 1, 2020 21:45:33 GMT -5
did not fit right.
Post by mauibird on Dec 1, 2020 21:55:32 GMT -5
So I deformed the box with hot water. I microwaved 4 cups of water till boiling. I then poured it on the spot I needed to deform, then pushed on it with the handle of a screw driver to deform it. It fits “ok” now. The coupler could be pushed on to the carb 1 or 2 more millimeters, but hopefully it should hold. We’ll see...
Post by mauibird on Dec 1, 2020 21:56:46 GMT -5
Post by mauibird on Dec 1, 2020 21:58:26 GMT -5
Post by mauibird on Dec 1, 2020 21:58:55 GMT -5
Post by mauibird on Dec 1, 2020 21:59:17 GMT -5
Post by 808ministroke on Dec 2, 2020 2:41:39 GMT -5
i have this delta clutch on my piaggio came from previous owner . is mine adjustable like thay aswell? with weights and varying amounts of preload? No, mine is the delta clutch You're right my bed that was a malossi fly i now know. Have you ever seen the koso Delta clutch? Works really good I'm sure it's a lot cheaper and forcing they can't find any more of them cept for this morning have
What have you noticed if any effect you get from either adding more pre load or more or less weight on the shoes
Post by Deleted on Dec 2, 2020 5:45:49 GMT -5
Have been eyeing this air filter for my Honda X8R. Now that I see it's dimensions in your build. I made decision to order one. Thanks
Post by mauibird on Dec 2, 2020 12:27:06 GMT -5
What have you noticed if any effect you get from either adding more pre load or more or less weight on the shoes The weights adjust the rpm hook up by a few hundred rpm’s and how hard or soft they hook up. I was getting some clutch squeal with my stage6 clutch bell until I adjusts the bottom weights outward causing shoes to grab harder/quicker eliminating the squeal.
Post by mauibird on Dec 8, 2020 16:07:49 GMT -5
Went to reassemble transmission, and I spun the threads on my main gear with my impact gun.😢
Post by mauibird on Dec 8, 2020 16:09:18 GMT -5
Primary Gear
Post by mauibird on Dec 8, 2020 16:09:50 GMT -5
