Post by Thebatman on Jan 6, 2011 6:57:35 GMT -5
Hey guys.... I also have a ag 4t... It has 800kms on the dial now... I havent studied enough so you may need to bypass this thread.... I just watched a valve checking vid.... About what is a break in on a 4t?.. it has had the 1st service... i notice a slight "rattle"(usually when wot)... i'm not sure if thats a 4t thing or if maybe my valves need adjusting.. it is hard to start alot of times... I was told that checking valves is needed with colder weather but i'm also thinking that wwith only 800kms, may not need touching.... :lol: ... seen where 4000kms+ is due for adjusting...i apologize if you are "chewing your cabbage twice".....
Post by 90GTVert on Jan 6, 2011 7:52:49 GMT -5
You can usually hear the valves ticking at any engine speed, so I don't know that your WOT rattle is the valves being out of adjustment. Secure it on the center stand and see if you can get it to rattle. Then you can look around a bit more and figure out where it's coming from better. Checking the valve clearances is not a bad idea. You could also adjust the idle mixture and speed once it's warmed up to see if that makes starting any easier.
Post by Thebatman on Jan 6, 2011 9:30:40 GMT -5
LOL... thats the video..... thanks brent.. I will check it out.. As far as i know, NOTHING has been turned on this thing yet. (cept i have started changing rollers...lol)
Post by Thebatman on Jan 12, 2011 13:32:56 GMT -5
Just a update;.... I have since removed the mirrors.(I couldnt see anyway, they hit my shoulder.. to narrow). I also removed the rear mud flap. (which sux if raining, sprays everywhere. (even with the rear fender)) I have "tinted" the lenses, wired up the front running lights now. Got a malossi 1000 main spring/fly springs to install and try to get the cvt in better shape..(threw in some 5.7g rollers).. Need to jet carb and install open air filter with some 4.5g rollers I will post a pic after i get one took in a few.... ;D
Post by Thebatman on Jan 13, 2011 19:19:54 GMT -5
Hey guys, Here is an idea of the "tinted" lenses... I will probably go back and lay 1 coat on the headlight when i install the blue runnin lights.. I also removed the mirrors so far... :lol:
Post by 90GTVert on Jan 13, 2011 19:29:38 GMT -5
Looks good. You've got a really nice collection going.
Post by Thebatman on Jan 13, 2011 19:37:55 GMT -5
Thank you man.... Yeah, i think it's becoming an obsession or something... :rofl: ... (I aslo have a cobra racer, that was suppose to have been a parts bike but is complete. :thumb: ) Sorry about the size of the pic and the quality of the pic.. Seems a bit dark in the living room for some reason....
Post by 90GTVert on Jan 13, 2011 19:41:32 GMT -5
No worries. We can see what's up and the forum is set to auto reduce the size displayed. ;D
Yer gettin' Kymcos so fast your signature can't keep up. :jaw:
Post by Thebatman on Jan 13, 2011 20:02:19 GMT -5
:rofl: :rofl: See, i told ya...Could be a very good example of O.C.D.... :stumped: :rofl:
Post by 90GTVert on Jan 13, 2011 20:09:03 GMT -5
O.K.D.? Obsessed w/Kymco Disorder
Post by Thebatman on Jan 13, 2011 20:10:36 GMT -5
Hey, That one even sounds better... :thumb: :rofl:
Post by Thebatman on Jan 27, 2011 9:56:43 GMT -5
Gonna install some "side marker" lights on the ag Here are the grips wt was so gracious to part with.. these will be on the ag today as well.. pic coming after..
Post by Thebatman on Jan 27, 2011 18:42:00 GMT -5
Sorry for the crappy pic, but the grips are installed.. ;D THANKS TIM... I have changed main spring to malossi white 1000, currently running leo 5.7g rollers.(which isn't right btw,maybe 5's). I NEED to jet, drill a cpl holes in exhaust, open air filter and then slap in some 4.5g and see what happens. (i know someone with about the same setup on his ag, is why i mentioned 4.5)
Post by Thebatman on Jan 27, 2011 18:42:51 GMT -5
DDUUUUUUHHHHHHHHH..........
Post by 90GTVert on Jan 27, 2011 19:15:25 GMT -5
:thumb: Looks better.
