Post by iwiketuddlz on Aug 31, 2015 17:09:56 GMT -5
Holy crap!!! 2.5mm is a crap load!!! Did you have the correct rod length??crank?? Those temps are extremely high!!! You should be smelling it burn I'd think!!
Post by sai on Aug 31, 2015 17:26:40 GMT -5
Holy crap!!! 2.5mm is a crap load!!! Did you have the correct rod length??crank?? Those temps are extremely high!!! You should be smelling it burn I'd think!! well I added more than 1mm to the base gasket to change the port timing... so... I actually don't smell anything burning... yet at least and I drove 20 miles just now
Post by iwiketuddlz on Aug 31, 2015 18:25:22 GMT -5
Maybe you're gage is reading incorrectly????i dunno
Post by sai on Aug 31, 2015 21:47:32 GMT -5
I think it is... I do max out at 241f at 10.000rpm . In the hot weather I don't know how it got to 287f yesterday... Must be a fluke
Post by spaz12 on Sept 1, 2015 15:10:04 GMT -5
That sensor is obviously wrong. Did you use any kind of wire to extend the lead? I know many come with a very short lead. If you did extend it, and you didn't use their extension, then that's what your problem is.
Post by sai on Sept 1, 2015 18:06:43 GMT -5
I do use the trail tech extension. Right now it's never hotter than 245f. It was a 1 tim fluke.
Post by spaz12 on Sept 1, 2015 18:19:15 GMT -5
245 sounds crazy for water temp. I never used the sensor that attaches to the head and with the readings you get, I never will. That's scary. It hasn't seized or boiled over so it must be fine. I'm not trying to scare you btw, I just don't like those numbers
Post by 190mech on Sept 1, 2015 19:31:55 GMT -5
245 sounds crazy for water temp. I never used the sensor that attaches to the head and with the readings you get, I never will. That's scary. It hasn't seized or boiled over so it must be fine. I'm not trying to scare you btw, I just don't like those numbers I agree!Time to test the gauge..Got a 'temp gun' handy?Chech the head and rad for real time temps after a ride. www.harborfreight.com/infrared-thermometer-93984.htmlOr the old school way,drop the temp sensor in a pot of boiling water(cant get over 212F) and see what the gauge reads..
Post by sai on Sept 1, 2015 21:11:22 GMT -5
The gauge is too small for the opening, so we created a metal adapter... Not sure if this is the cause. I'll look into the infra red, but I just don't have dispensable cash right now
Post by 190mech on Sept 2, 2015 4:31:14 GMT -5
The adapter shouldnt change the readings as long as the tip of the probe is in water..Might check with your mechanic about borrowing a temp gun,surely somebody has one in their tool box!
Post by derbiman on Sept 2, 2015 17:22:52 GMT -5
I just bought an infrared temp gun at Sam's Club for $20. Cheaper than Harbor Freight!!!
Post by sai on Sept 3, 2015 10:34:36 GMT -5
I hope it's just reading a little high. I'll borrow a temp gun from someone. (need to save money now)
So ride it WOT for a n hour or so, then stop while the engine is still running and measure the temp that way? Should I aim at the cylinder head or the cylinder itself?
Post by 190mech on Sept 3, 2015 12:08:18 GMT -5
The head ought to be the hottest area,but its interesting to check the rad and cylinder too!
Post by iwiketuddlz on Sept 3, 2015 15:52:34 GMT -5
Hey 190.. Wonder why my cht stays lower than water temp??by approximately 20degree or so
