Post by sai on Aug 6, 2015 11:20:45 GMT -5
So what does a stator do? And how much MPH is 1 Horse Power?
Post by 90GTVert on Aug 7, 2015 9:14:58 GMT -5
The stator provides power for charging the battery and lighting. You can play around with calculators like the one below if you wanna try and make a guess at how many MPH one HP will equal. May not be accurate though. www.wallaceracing.com/Calculate%20HP%20For%20Speed.php
Post by derbiman on Aug 7, 2015 9:28:06 GMT -5
I was just wondering and I mean no offense,but what are your expectations with all of the upgades?
Post by sai on Aug 7, 2015 12:20:50 GMT -5
Is it possible that a bike loses performance late at night when it's cold?
I forgot how my AC was, but my LC loses power and speed yesterday when I was riding late at night for 30 miles. I can feel it was cold because my hands were freezing.
Post by 90GTVert on Aug 7, 2015 12:47:27 GMT -5
Maybe it's a little lean for cold nights when tuned for summer?
Post by sai on Aug 8, 2015 9:36:19 GMT -5
Maybe it's a little lean for cold nights when tuned for summer? I thought that if it's tuned for summer, that means it'll run a little richer in the cold weather ?
Post by 90GTVert on Aug 8, 2015 9:45:38 GMT -5
Hot and wet weather and high elevations require less fuel. Cold and dry weather and low elevations need more fuel. Usually a cool night won't be too bad though, unless your tune is really on the edge.
Post by niz76 on Aug 8, 2015 9:47:43 GMT -5
Summer= Downjet (run a little leaner) Winter= Upjet (run it richer)
Post by sai on Aug 8, 2015 10:09:35 GMT -5
So my crankshaft from Top racing and Naraku bearings will be here next week...
How hard is it to take the engine case out? And do I need to disconnect everything?
THrottle cable, fuel / oil hose, cylinder head, carb, etc?
Yes, someone will help me to split the case and put it back together.
Post by 90GTVert on Aug 8, 2015 10:23:39 GMT -5
You'll need to disconnect and wires and hoses that go from the engine bits to the frame and remove the rear brake or disconnect the cable. Prob easiest to take the carb off vs disconnecting the cable and hoses. Find a way to support the scoot safely. Remove the bolts for the mount and the shock. Then the engine should be able to come out.
Post by sai on Aug 8, 2015 10:28:45 GMT -5
You'll need to disconnect and wires and hoses that go from the engine bits to the frame and remove the rear brake or disconnect the cable. Prob easiest to take the carb off vs disconnecting the cable and hoses. Find a way to support the scoot safely. Remove the bolts for the mount and the shock. Then the engine should be able to come out. do you have a vid of doing this?
Post by 90GTVert on Aug 8, 2015 11:03:53 GMT -5
Post by derbiman on Aug 8, 2015 11:14:44 GMT -5
Sai,I was wondering what kind of goals are you looking to achieve with all of the upgrades? I am interested in your progress and have been watching your build for some time.
Post by sai on Aug 9, 2015 12:10:46 GMT -5
So I'm wondering, when my bike was still AC on the top speed, I can hear and feel the engine just work so fast to the point that I barely feel any friction or revving and this for me usually means I'm about to seize it. (trying to describe as best as I can)
Now that I'm on LC, do I need to worry about this still? Currently using a 93 main jet. My friend said that this is even too high for Colorado as he uses a 102 in CA.
Post by iwiketuddlz on Aug 9, 2015 14:27:28 GMT -5
With my experience in soft seizing a LC cylinder.... it gave me no warning at all .... Nothing like an AC cylinder anyway,,, just make sure your plug chops are good and you should be ok!!!! Just my 2cent....
