Post by 2strokezumatx on Feb 28, 2016 20:54:01 GMT -5
Maybe not... Ha! Oh well
Post by 2strokezumatx on Feb 28, 2016 21:16:53 GMT -5
Sooo been out a bit, tore the joker down again because the idle thing came back! Heres what i found that seems to have done fixed it. I most definitely had a too thin a base gasket (weird it didn't damage the piston and may have been causing a heat issue from detonation??) So thicker gasket, moved the needle down to lean out the cruise speed. I needed that anyways-acceleration improved and can use mix screw to fine tune it. Also found tiny vacuum leak to the petcock. So happy now was not happy with the cvt case color so now it's brighter like BAM! magenta... I know not for everyone but that's why I'm special also trying out a e-start delete- been wanting to try it out. Will c if it frees up any power at all? Because real men don't use electric starter
Post by 2strokezumatx on Feb 28, 2016 21:23:23 GMT -5
Ohh and check this, trying out a digital color display for the dash... Mph can't keep up with the acceleration though.
Post by 2strokezumatx on Mar 5, 2016 1:52:24 GMT -5
Okok.. Starter gear and all went back in. After testing without it, i was impressed with the smoooothness of the motor after the delete but even with a re-tune of the trans. There's NO performance gains (for me) so after sleeping on it i decided to keep the e-start just won't use it unless having issues and for when i run w/ no cvt cover. Hope everyone is having fun with yr rides... I did some carb tuning and droped my weights to 19.2 w/ naraku white contrast spring switched from a worn out 08 rear pulley to a 04 and amn it pulls hard now! I'm shocked there was more to be had, even scared some kids in the neighborhood. Spring is here and finally i have my scoot ready for the annual H-town scoot down just to find out there is not going to be a scooter rally this year! WTF! Still can't believe it so that's that. Calling out to anyone that reads this who either lives in Houston or knows of a scooter tuning dude here in H-town that would like to ride, let me know? Thanks guys. Later
Post by 2strokezumatx on Mar 10, 2016 16:53:11 GMT -5
So I've had this issue with the Athena Race exhaust, the spring hook keeps breaking off and then the pipe will slide off under acceleration so i decided to have it welded up into a solid pipe plus strengthen a area that was cracking. A day later and $50 it's done - happy with it. Also ported the exhaust a little bit.
Post by 2strokezumatx on Mar 10, 2016 16:55:49 GMT -5
Post by 2strokezumatx on Mar 10, 2016 17:08:26 GMT -5
Post by 2strokezumatx on Mar 19, 2016 0:43:27 GMT -5
This thread is dead ( dunno) ha! Couldn't help it. (Cold beverage's.
Post by Clank on Mar 19, 2016 4:09:38 GMT -5
This thread is dead ( dunno) ha! Couldn't help it. (Cold beverage's. Quick get the defibrillator spaz12, & PIG! 90GTVert 70cc's more bore STAT! 190mech prep the machine room! FrankenMech & niz76 scrub down for a gear oil change! We can save this one. 2strokezumatx hang on buddy! Don't go into the light it's oncoming traffic. You can pull through. Just a little more........
Post by spaz12 on Mar 19, 2016 5:53:39 GMT -5
This thread is dead ( (bfg)dunno) ha! Couldn't help it. (Cold beverage's. Don't go into the light it's oncoming traffic. You got me with that line
Post by 2strokezumatx on Mar 24, 2016 18:16:01 GMT -5
Man I knew I liked you two guys from the start.... thank you guys I really really needed that laugh right about now. (Thank you clank)
