Post by ryan_ott on Mar 22, 2016 11:25:31 GMT -5
Hardware store, you can use hex nuts in place of the square ones. If your replacing the battery they usually always come with them.
Post by mistervon on Mar 22, 2016 12:06:01 GMT -5
Scooter came with two batteries, gotta get a charger and see if they work. Can I go to harbor frieght for the the screws or advanced auto??
Post by ryan_ott on Mar 22, 2016 12:28:45 GMT -5
Auto part store or like homedepot, lowes, true value etc. harbor freight doesn't have hardware I don't think
Post by mistervon on Mar 22, 2016 13:15:13 GMT -5
Numbers on engine AM01-101066. Also I have a 4 way fuel valve but only have 3 hoses available
Post by mistervon on Mar 22, 2016 13:55:37 GMT -5
What else do I connect to this fuel valve, only three hoses available. Can anyone confirm this engine?
Post by dan50 on Mar 22, 2016 17:14:01 GMT -5
Just to start off 2002 Alpha Sports Kaliber LS 1119 on clock Disk Front Brakes/Drum In The Rear I'm going to be posting here alot, as I'm new to the hands on scooter world/tuning. My first question is I have what's looks to be a 4 way fuel valve but I assume this is a 2stroke engine. Is that possible? Also how do I hook this all back up? I have a 2003 Kaliber LS and the fuel pump only has 1 outlet.
Post by mistervon on Mar 22, 2016 17:58:10 GMT -5
When I run the vin it says 2002. The fuel valve have 4 outlets what do I do? The fuel has been drained it's ready to be started just gotta connect the hoses? I need you guys help on this one.
Post by mistervon on Mar 22, 2016 17:59:52 GMT -5
I'm talking the fuel valve the silver looking piece. And Dan check out aeon krypton on Google search.
Post by spaz12 on Mar 22, 2016 18:02:10 GMT -5
Replace the petcock with another fuel filter for now, or something to connect the two hoses, or a longer hose...
Post by ryan_ott on Mar 22, 2016 18:02:25 GMT -5
Likely one is a vent. The one that has corrosion looks like it's never been attached to anything. One will be vacuum likely the one on the side. The others will be in and out. Later you may want to bypass it looks easy to do on yours you just need a manual shut off valve.
Post by mistervon on Mar 22, 2016 18:07:06 GMT -5
It says in and out and vent and iiboi or something to that affect on the valve. I'm kinda lost. The in is already connected. I have connected the out to the carb. But the other hose is not even the size to fit any parts os the fuel valve.
Post by dan50 on Mar 22, 2016 18:26:39 GMT -5
When I run the vin it says 2002. Where did you find the VIN number? I can't find a VIN on my 2003 Kaliber LS. Is yours distributed by Alpha Sports?
Post by mistervon on Mar 22, 2016 18:29:00 GMT -5
The vin number was on the title. But the vin on the scoot on the front part ain't the same. If that's even the vin. These scooters are rare imports. But I think they use the 1e40qmb engine. What's yours got?
Post by ryan_ott on Mar 22, 2016 19:22:46 GMT -5
Going by the pic you posted its not the 1pe40qmb. More like the variation of the Honda af16 that kymco offered. Is the intake atrached to the engine case?
Post by ryan_ott on Mar 22, 2016 19:25:57 GMT -5
Is that a vertical cylinder, plug facing seat?
