Post by mistervon on Mar 22, 2016 19:41:21 GMT -5
Yes the spark plug is vertical. I pull the cap up. What engine am I working with? The airbox is like attached to the carb like you have pry them apart.
Post by spaz12 on Mar 22, 2016 20:33:22 GMT -5
Is that a vertical cylinder, plug facing seat? Looks like a vert motor to me too. EDIT: lol missed the next page. Again
Post by triesandluth on Mar 22, 2016 23:58:10 GMT -5
I have that 4 way petcock on my tgb. There is a point at the top of the fill up hole that connects to a hose that went to that vent nipple. Here's mine. Here's where my vent hose connects
Post by mistervon on Mar 23, 2016 6:47:42 GMT -5
Lost at "fill up hole" ? Does the fuel valve mount some where?
Post by mclark999 on Mar 23, 2016 6:51:51 GMT -5
Lost at "fill up hole" ? Does the fuel valve mount some where? At the gas cap.
Post by mistervon on Mar 23, 2016 7:01:42 GMT -5
I will check for that, don't really recall seeing anything like that. (Vent hole) Also this hose in the red ring, does this connect to my fuel valve? It doesn't seem even go on there when I tried it.
Post by mistervon on Mar 23, 2016 9:48:38 GMT -5
I been on YouTube and I been looking at the Mbk booster next generation. And it looks so similar to my scooter. The headlights, tailights, even some body panels seem the same. The know mbk booted next gen's have the vertical minarelli. Can I use parts from mbk?
Post by spaz12 on Mar 23, 2016 13:38:00 GMT -5
The way the air shroud is bolted to the case makes me think that it's a vertical minarelli. Almost sure of it.
Wouldn't know anything about the way it looks and what might fit because you haven't posted any pictures of the scoot itself. Assuming it is it's twin then there is a good chance the bodywork will fit. I know that people with prebug Zuma's can fit the BCD panels that are designed to fit the MBK Booster onto their Zuma's. Of course MBK is owned by Yamaha.
Post by mistervon on Mar 23, 2016 14:05:35 GMT -5
Here she is. I'm thinking this is the twin to the Mbk booster ng. Same vertical engine. Same tail lights and head lights.
Post by spaz12 on Mar 23, 2016 14:12:37 GMT -5
Then you might be able to use the body panels and other pieces... But like the prebug Zuma and the Booster, there are slight differences in the way the panels mount and so they have to be modified slightly, but doable.
Post by mistervon on Mar 23, 2016 14:35:46 GMT -5
All I really want to change as far a body panels would be the head piece with the lights and the rear undertail piece. Other than that, just a smooth paint job.
Post by triesandluth on Mar 23, 2016 16:21:25 GMT -5
Lost at "fill up hole" ? Does the fuel valve mount some where? At the gas cap. What he said. My brain wasn't functional last night.
Post by mistervon on Mar 23, 2016 17:56:36 GMT -5
It's all good. So if I don't a vent hole on the gas tank which I dont. Where does it connect to instead? How would I switch out to manual fuel valve?
Post by spaz12 on Mar 23, 2016 17:58:28 GMT -5
That vent hose does not need to be hooked up
Post by spaz12 on Mar 23, 2016 18:09:00 GMT -5
