Post by arkie on Jul 5, 2017 21:35:14 GMT -5
Ok so I got another question. This time about your mig light. Is it so you can see with the hood down and no arc? Or is it because you maybe got too dark a shade on your hood? No auto dark hood I assume. I can see real advantage if say for example you were doing lots of stitch welding and no auto dark hood.
Post by thephranc on Jul 5, 2017 21:48:19 GMT -5
I have bad lighting in my hovel of a shop. What it does is light up the metal around the tip while welding. Otherwise I can only see the puddle even with the hood turned all the way down. I have flood lights too but in the summer its just too hot.
Post by thephranc on Jul 9, 2017 15:19:43 GMT -5
So to recap thanks to photobucket.... Scoot then and scoot now. Alum battery terminal thing. Supper ruff.
Post by thephranc on Jul 25, 2017 18:35:16 GMT -5
Post by thephranc on Jul 25, 2017 18:36:57 GMT -5
Note to self: tint back side of lens because the front is too curved.
Post by thephranc on Jul 26, 2017 18:37:50 GMT -5
Post by thephranc on Aug 6, 2017 12:13:31 GMT -5
Was going to start the bike today. Filled with fluids a, all good then gas pisses out of the bung where the pump screws on. Ruined the paint.
Post by drc174 on Aug 6, 2017 13:44:18 GMT -5
Bummer but not the end of the world.
Continue the mockup, make it run, then take it apart and repaint. Always go in with a "What did we learn?" attitude towards stuff like this.
Post by 'O'Verse on Aug 6, 2017 13:52:24 GMT -5
Happened to all my do it yourself rattle can paint jobs. Especially around the tank area. Even using the gas resistant clear coat. Something about the factory grade paint and sealer that prevents that from happening. Atleast it's in a spot that maybe unnoticeable. EDIT: When you first commented on my build thread that you were shooting for 100mph. I thought you were kidding. But now that I see your rocking a 250cc in a lightweight frame it might actually be possible.
Post by thephranc on Aug 6, 2017 14:41:10 GMT -5
Bummer but not the end of the world. Continue the mockup, make it run, then take it apart and repaint. Always go in with a "What did we learn?" attitude towards stuff like this. Im sure it'll be blown apart a few times before its on the road. Just sucks. I might be able to paint it all assembled before the tank goes in.
Post by thephranc on Aug 6, 2017 14:43:29 GMT -5
Happened to all my do it yourself rattle can paint jobs. Especially around the tank area. Even using the gas resistant clear coat. Something about the factory grade paint and sealer that prevents that from happening. Atleast it's in a spot that maybe unnoticeable. EDIT: When you first commented on my build thread that you were shooting for 100mph. I thought you were kidding. But now that I see your rocking a 250cc in a lightweight frame it might actually be possible. Its only a stock 250. If need be after cvt tuning, they make some 4 valve heads and cam .
Post by 90GTVert on Aug 7, 2017 4:07:35 GMT -5
This is why I painted T2's frame with this stuff. They just had original when I bought it last. I've constantly got fuel/oil on it somewhere and it's fine. It mostly wears off over time in areas where there's some kind of contact, like my heels sitting against the frame. Cost is the only drawback for me. No color options may ruin it for you. Cost is justifiable IMO... I mean if you paint it once every few years vs once every fuel spill... www.eastwood.com/chassis-blackI've also used this quite a bit and it has held up well to fuel spills and brake cleaner. Again, not lots of color choices. Not as resistant as Chassis Black above, but for a little cheaper product that you can walk into an auto parts store and grab, it does quite well. I think I paid about $7 a can last time I bought it. duplicolor.com/product/wheel-coating
Post by thephranc on Aug 7, 2017 18:20:04 GMT -5
This is why I painted T2's frame with this stuff. They just had original when I bought it last. I've constantly got fuel/oil on it somewhere and it's fine. It mostly wears off over time in areas where there's some kind of contact, like my heels sitting against the frame. Cost is the only drawback for me. No color options may ruin it for you. Cost is justifiable IMO... I mean if you paint it once every few years vs once every fuel spill... www.eastwood.com/chassis-blackI've also used this quite a bit and it has held up well to fuel spills and brake cleaner. Again, not lots of color choices. Not as resistant as Chassis Black above, but for a little cheaper product that you can walk into an auto parts store and grab, it does quite well. I think I paid about $7 a can last time I bought it. duplicolor.com/product/wheel-coatingI like the duplicolour wheel coating stuff. all the trim on my AMC is done in it. Going to see if I can put a real automotive clear on top of the rattle can. Not sure how well the two mix. Might try this eastwood stuff or just use the duplicolour air gun clear. www.eastwood.com/eastwood-s-2k-aerospraytm-high-gloss-matte-clear.html
Post by thephranc on Sept 20, 2017 17:04:48 GMT -5
Fixed gas tank plumbed to the carb no leaks, cooling system 100% installed no leaks, no gear leaks,no oil leaks. Go to start and started wont kick over. Relay makes wierd sounds figure bad relay. Burb coolent hoses get a good burble wayer goes down so I fill it back up. Next day see small oil in morning before I go to work. Get back to the shop and see little drips on the ground. Leave a hunk of cardboard under to see if I can find the spot. Tonight get back from work and huge puddle.Find it leaking from the top seal for the stator wires.....pop dip stick water....
So I have a cracked head, cracked block,wrong head gasket of it even has one. I think it was assembled with a sealent paste.
Looks like the engine needs to be taken apart and while im in there see if I can make things better with a port job.
The heat sink popped off of my cpu so Im down a computer,just using the phone . Im in no hurry to fix that. AMD prices should fall a little in a couple of months with the new chipsets out for a little while.
Post by thephranc on Sept 24, 2017 17:55:55 GMT -5
This wonderful mix poured out of the oil drain. There is a layer of oil on top with big air bubbles trapped under it. and the milky part is all a punch of tiny bubbles whipped up from the agitation of it coming out.
