Post by 90GTVert on Apr 15, 2011 20:12:07 GMT -5
I agree, it sounds like it could be rich in spots. Regardless, it's good to hear it fired up again after being down for a while. Congrats on getting the liquid cooled conversion done and running! I think the hard part now is gonna be resisting temptation to immediately burn up the credit card with the kind of parts that liquid cooling can support. :devil:
Post by jmkjr72 on Apr 15, 2011 20:48:53 GMT -5
yeah i gota keep it civil thru this scooting season i think i realy messed up something in my hand the clutch on the stella was just so hard on my hand after the last wreck so i need a hyd clutch set up for it and with over 10,000 miles on the crank i need to split the case but i made a contact that will be willing to help me find a lc aerox engine and rim
Post by 90GTVert on Apr 15, 2011 23:19:24 GMT -5
Very nice! Aerox cases are like fantasy pieces for us Minarelli guys in the states. :drool:
Post by jmkjr72 on Apr 17, 2011 13:07:27 GMT -5
well i have orderd the 90 and 85 mj for the carb and of course whil i was at it i had to add more parts to the list i added the stage 6 drive face to go with the stage 6 varatior i already have in it now i just need to order some nice weather so i can get the darn thing tuned
Post by 90GTVert on Apr 17, 2011 16:05:43 GMT -5
If you find a place to order that weather, let us know! They'll be an overnight success once the scooter and motorcycle community is aware. ;D
Post by jmkjr72 on Apr 18, 2011 14:19:57 GMT -5
well while im waiting on my jets to get here i messed with the a/f screw and the needle and got her running better on the stand still sounds rich up top but while im waiting on parts i decided to take a page from 90gtverts book on trans cover venting from the side with a fresh coat of paint it will look pretty stock from the top i cut a hole above the clutch and bell becuase of the way the zuma cover i went with the top of the clutch and one from below and i added 2 to the front by the varatior
Post by 90GTVert on Apr 18, 2011 16:09:36 GMT -5
Nice job keeping it inconspicuous.
Post by jmkjr72 on Apr 18, 2011 16:39:19 GMT -5
thanks i bet if i found some screen or something like that to put over the vents if some one saw them they wouldnt even realize they werent stock i liked the way you did yours so thats what i was kind of aiming for i would think it should vent almost as good as the ones you have on the front side
Post by 90GTVert on Apr 18, 2011 18:35:24 GMT -5
Those foam vent plugs would be cool, look kinda stock, but I've only seen 'em in round.
Post by jmkjr72 on Apr 18, 2011 18:52:33 GMT -5
thats an idea i can get some small square screen and get some cut your own black filter foam and make my own deal like that
Post by 90GTVert on Apr 18, 2011 18:59:14 GMT -5
Good thinking. Wonder if you could use some large grommets on the front holes at least. Make the edges look smooth. I know some round grommets will flex pretty easily to fit oddly shaped areas. Had to do that with some odd wiring through my firewall before.
Post by 2strokd on Apr 19, 2011 8:21:55 GMT -5
Looks nice! Good work! Ive seen some cut holes in the rear of the case on your style mina. because the cover is thinner and the case wider or thicker (better idea IMO) and the rear pulley is all the way in the case on yours. For sure what you did will help! Im not sure i could cut holes in mine?
Post by jmkjr72 on Apr 19, 2011 12:46:08 GMT -5
i need to get some filter foam and repaint the cover
Post by jmkjr72 on Apr 21, 2011 13:32:33 GMT -5
well im waiting for my battery and my jets so i can take a test run
but for shits and giggles i hooked up the little tach i use to set idle and keep an eye on my lawn equipment
i never thought to use it on the scoot as it only goes to 9999 rpm
well i found out that when you hit 9999 it starts all over again
so on the bench i was able to rev it around to 13000 before i decided to let off the throttle
so looks like i will have to play gently with my right hand when im out scooting
Post by 90GTVert on Apr 21, 2011 13:47:54 GMT -5
Yer really gonna need a new pipe. ;D
