Post by jmkjr72 on Sept 8, 2012 12:55:28 GMT -5
yeah neither did i till i went to mount the engine to see if i needed an even longer shock then what mareames sent with the engine
the mounting ears are closer together then on the zuma so that means i got to order a mounting tube from adly
im just hopeing i can keep that gear ratio with the over sized vario and the 8.83 gear ratio 10,000 rpm should be about 75 to 80 mph
Post by 90GTVert on Sept 8, 2012 13:02:25 GMT -5
That's a lot of gear to pull. I'm interested to see how it works out. I've got those gears that will fit my Venus, but I've never tried them. I figured even if the 96cc did OK with them, I don't really want that little thing doing crazy speeds... and a strong takeoff is a lot of fun.
Post by jmkjr72 on Sept 8, 2012 13:44:13 GMT -5
yeah i know its a lot of gear i may hold off on the stage 6 over sized vario at first im willing to give up some take off to be able to run 60 to 65 all day as i live very rural so most all my riding is on 55 mph roads where people run 60 to 65
Post by martyd on Dec 29, 2012 1:13:51 GMT -5
Did you have to have an overflow bottle ?
Post by jmkjr72 on Dec 29, 2012 13:43:11 GMT -5
for my set up it makes it a lot easier to add coolant and keep an eye on the level as the rads are inside the body work
Post by waltinhawaii on Jan 2, 2013 1:11:09 GMT -5
I bought that same cylinder kit and thought much the same; ports are ok, but rough and the subports too square and don't go far up the side enough. I'm still working out which crank to get, though.
aloha, walt
Post by jmkjr72 on Jan 2, 2013 15:13:00 GMT -5
on that engine i have the athena crank 43mm stroke crank that you do not need to machine the 50cc case to work with it its a small taper small spline crank with 12mm wrist pin
