Post by 90GTVert on Dec 8, 2011 19:51:08 GMT -5
The Polaris 90s are short case.
What size belt is on that thing?
Post by jmkjr72 on Dec 8, 2011 22:52:10 GMT -5
ill check tomorrow we had order of the arrow tonight so i just got home
but i did find out my son is swtiching to engineering class in school (this is the class that they build mini choppers in)
so we may be looking for another scoot in the near future for him to realy start to wrench on his own
Post by 90GTVert on Dec 9, 2011 1:29:33 GMT -5
;D :thumb:
Post by jmkjr72 on Dec 9, 2011 19:23:24 GMT -5
it has a bando belt in it pn 23100-117-000
Post by 90GTVert on Dec 10, 2011 2:55:24 GMT -5
878 17 28
Thanks.
Post by jmkjr72 on Dec 10, 2011 14:40:21 GMT -5
ok looks like the adly 90cc atv engine uses the same belt and the same trans cover gasket so when i get my crank and bore if the machine totals is going to be more then 250 buck i will be better off buying brand new adly cases
Post by jmkjr72 on Dec 11, 2011 16:26:01 GMT -5
well i have my z125 intake on the way i have steel for my new engine mount to scretch it out a bit work is picking up so hopefully soon i can order a crank and bore so i can get this thing to a machine shop
Post by jmkjr72 on Dec 17, 2011 15:33:09 GMT -5
well i got my intake today and it looks like with a plate that uses flush mount allen screws it will work well that is till i went to put my injecter in the bung the bung is larger then my injecter but i have a bung that came with the injecter so i will have to drill out the existing bung so it slides in nice and tight then have it welded (i dont have the right gas to weld al or the right wire and by the time i get it all im sure it would be cheaper to have it done) and if i go this route i might have the intake welded to the adapter plate i just have to make sure i can get bolts thru to the block when i pick my clocking
Post by 90GTVert on Dec 18, 2011 0:03:33 GMT -5
Nothing can ever be easy, but at least it's another step ahead.
Post by jmkjr72 on Jan 19, 2012 19:38:53 GMT -5
ok i have a goodie on the way a 43 mm stroke athena crank i know i was going for budget and this is a budget part it was given to some one on another forum and he didnt want to spend the cash to buy the matching athena kit and it has just been sitting so he is shipping it off to me so it can get used and abused now he was thinking that the case may not need to be bored out for this crank and if so it will save me on the machine work but i wont know till i have this little beast in my hands and if this is of the same quailty as the crank in the hyper race kit then the crank should be good for 15,000 rpm i thought the stock stroke on the 90s was 42mm so if i get a 53mm bore ill have 95cc if its a 54mm bore it willl be 98cc
Post by 90GTVert on Jan 19, 2012 19:47:24 GMT -5
Very nice.
Stock 90 is usually 42mm. Most of the high end stuff (2FAST, Stage6 R/T...) are for 44mm.
Post by jmkjr72 on Jan 19, 2012 20:31:35 GMT -5
yeah that stuff is not in my budget im still thinking the hoca 53mm lc bore from scooterparts or a 54mm lc bore from gforce
Post by 190mech on Jan 19, 2012 20:43:16 GMT -5
You'll likely still need to cut the crankcase with that crank and for sure the cut cyl flange to allow a 53-54 jug to drop in.. Nice crank!! :thumb:
Post by 2strokd on Jan 20, 2012 7:46:18 GMT -5
Nice! Agreed! Also, do some "flow path" cutting if ya can? Of course im sure you have been thinking about that for some time im sure... Cant beat bang for buck HP and torque! Sure you can make a 68-80cc rip and make HP up top, but these stroker,s make serious ToRqUe right off idle.
Post by jmkjr72 on Jan 25, 2012 22:22:34 GMT -5
well the crank was shipped out yesterday and today or monday my oil pump will be sent out
so all i have left to get is my bore
and i should have a toasted stator on the way as soon as a friend replaces the bad one in his zuma
so i will send that one in to r&m stator to have them rewind it and get some more juice for my efi
