Post by Chris Cristini on Jul 6, 2016 18:11:04 GMT -5
Ah so I should stop riding it with the stock Mina exhaust? I don't want to fry it lol I have to fix the gear box it make noise when engine braking still plenty of oil in there.
Post by 90GTVert on Jul 6, 2016 18:40:25 GMT -5
I ran a stock 49cc pipe for many miles on a 96cc without issue. A small stinger on a tuned pipe, not so much. Started killing the top of the piston very quickly trying that.
Post by Chris Cristini on Jul 6, 2016 18:48:40 GMT -5
I think I will leave it then I enjoy going 40 uphill anyways well not GPS verified I will take the gear box apart tomarow to figure out if I put the gear shim in between the gear cover bearing and the gear or if I left dirt in there lol I had to rush it which sucks because that's not good. Thank you!!!! Maybe in the future I will mess with this $90 cheapy
Oh I forgot to mention the original clutch had yellow springs
. Maybe I should try the ATV spring could be why I have poor acceleration at first the 49 took off from standstill faster and could do Wheelie's I can't with the 90. more tuning.
Post by Chris Cristini on Jul 7, 2016 16:44:10 GMT -5
I have been reading for days lol I must be dumb headed the new 90 has horrible throttle response from idle it kicks in after at wot at around 5mph and takes off really well I thought it might be what frankenmech suggested about checking the CVT torque pins and grease them but I checked all of it when redoing the seal on my gear box. I am using the same carb as the other engine have not made any adjustments yet because I don't want to hurt it I can't tell if it is lean or rich. it also starts and idles well with out throttle. I have been messing around with contra springs and I think the yellow one works better so far but got to get the carb correct before I decide does any one know if I should use the ATV main/pilot jets with the 49cc exhaust?
Post by arkie on Jul 7, 2016 17:13:42 GMT -5
Check the plug. Let it tell you.
Post by Chris Cristini on Jul 7, 2016 17:22:36 GMT -5
Check the plug. Let it tell you. After all I read I didn't think to do that my god lol thank you! White is bad and dripping is bad so if it is a nice brown then its good? I will take a pic of it soon lots of family crap to do sigh. I will use this nice chart.
Post by Chris Cristini on Jul 7, 2016 18:13:20 GMT -5
I guess I could start with needle adjustments it is almost all the way up I'll bring it down one notch at a time.
Post by arkie on Jul 7, 2016 18:42:16 GMT -5
That looks good in that you seem to be on the rich/safe side of things. And yes the needle rather than the jet is where you want to go I think.
Post by Chris Cristini on Jul 7, 2016 18:52:21 GMT -5
Thanks yo!!! I thought it looked like 1 through 3 on that scale I will try to get it closer to dryer conditions.
Post by niz76 on Jul 7, 2016 19:09:28 GMT -5
Yep looks a little rich. Could try the center slot on the needle- get the main jet dialed in, (looks like you could go down a little) then after you get the main jet/WOT squared away, finish off by tuning the needle for good mid-range throttle response...
Post by niz76 on Jul 7, 2016 19:11:03 GMT -5
What's your compression and squish clearance? Those seemed to be key to waking up my 90 and unleashing the beast!
Post by Chris Cristini on Jul 7, 2016 19:30:57 GMT -5
Ah haven't checked I need to do that soon as well as clean it up more I'll start all that and document more of the build had to rush things.
Post by Chris Cristini on Jul 9, 2016 18:49:40 GMT -5
Post by 90GTVert on Jul 10, 2016 20:07:52 GMT -5
Post by Chris Cristini on Jul 10, 2016 20:45:22 GMT -5
Thank you Brent I have been waiting so patiently to tune and figure out what I want to do its been raining like a fcker here lol I like LC for some reason it runs cooler I think anyway and I think more can be pulled out of it for power. I really would only like a reliable 55mph cruise should not be to hard considering I'm almost there not verified. I have read all of the threads relating to this and I am sure I made the right decision with this adly engine thankful this forum exists!!! All other forums I have been apart of suck. I have never been able to make anything faster beyond stock as far as the project cars I have had so I said to my wife this time I'm not selling my project lol. Hopefully tomarow is a better day I can start messing with the carb exhaust and maybe advance timing very slightly.
