Post by niz76 on Feb 20, 2017 19:36:54 GMT -5
Yeah a hotter plug is harder to foul. On some distributor sites I've seen it recommended to go with a hotter plug (lower number for NGK) for "stop n go" or "city driving" and a colder plug (higher number for NGK) for more "touring" or long wide open driving...
Post by tsimi on Feb 20, 2017 20:08:58 GMT -5
What plug are you or were you using?
Post by nelson on Feb 20, 2017 21:29:42 GMT -5
What plug are you or were you using? Br9es I think, might be br9hs
Post by tsimi on Feb 20, 2017 21:39:23 GMT -5
What's your setup?
Never mind...now that I accessed the forum with my PC I can see your signature.
Post by benji on Feb 20, 2017 22:31:58 GMT -5
I've heard lots of bad stories about those Chinese fake okos. You can get a new genuine Taiwanese oko for like $70 or a used mikuni vm24 for cheaper, I'd go w either one of those.
Post by Lucass2T on Feb 21, 2017 1:37:51 GMT -5
Id go with the VM, best would be a TM.
Post by ryan_ott on Feb 21, 2017 9:19:15 GMT -5
How's the condition of your silencer, if it's packed of carbon that could foul plugs, possible but maybe not likely here. Just another thing to check.
Post by Lucass2T on Feb 21, 2017 10:41:20 GMT -5
How's the condition of your silencer, if it's packed of carbon that could foul plugs, possible but maybe not likely here. Just another thing to check. But that would limit power all the way, he didn't mention loss of power.
Post by nelson on Feb 21, 2017 10:45:36 GMT -5
The power is there, just sometimes it actually misses like the plug isn't firing and cutting out.can't be silencer, I just bought it 4 months ago barley have any time on it.
Post by ryan_ott on Feb 21, 2017 11:28:40 GMT -5
Like I said not likely...
Reading back through looks like you've been fighting this since the beginning. I didn't see mention of what ignition your using. If it's stock it could be failing on you or just not up to the task your asking if it. Rpm wise. Not sure if it's relevant but on my airsal 77 it ran beautiful with the MVT on it then I tried the stock ignition to see how it would do. Fail, it ran like trash breaking up and would not rev out. It was acting rich. Do you have another motor you can swap parts between?
Post by 2TDave on Feb 21, 2017 11:46:32 GMT -5
Have you advanced the stock iggy? On my current setup it would cut out with the stock timing. Once advanced it cleared right up.
Post by nelson on Feb 21, 2017 14:27:24 GMT -5
Have you advanced the stock iggy? On my current setup it would cut out with the stock timing. Once advanced it cleared right up. Yes, running stock iggy not advanced. I just popped in a br8es and ran like a champ back to work. I have to hit the freeway for a few miles so I can't have it acting like poop. I did notice the filter was really dirty so I just took it off. Was on lunch break in a hurry. I will make a vid of it running great on the way home.
Post by nelson on Feb 21, 2017 14:30:48 GMT -5
Like I said not likely... Reading back through looks like you've been fighting this since the beginning. I didn't see mention of what ignition your using. If it's stock it could be failing on you or just not up to the task your asking if it. Rpm wise. Not sure if it's relevant but on my airsal 77 it ran beautiful with the MVT on it then I tried the stock ignition to see how it would do. Fail, it ran like trash breaking up and would not rev out. It was acting rich. Do you have another motor you can swap parts between? Well of course, what gear head only has one motor? I have a 94cc jog but it runs good and don't want to mess with it. I have a complete stocker also, I plan to steal some parts off of. Someone please anwser this question. What should my head temp be? It's 70 here ambient and I ran around 165 degrees. Is this hot enough? Could running at such cool temp cause this problem?
Post by nelson on Feb 21, 2017 14:32:37 GMT -5
Have you advanced the stock iggy? On my current setup it would cut out with the stock timing. Once advanced it cleared right up. How many degrees? I would need to notch the stator but I might have one with notches. Just 3-4 degrees? This is for better bottom or top end? Right now with new plug there is plenty of both
Post by nelson on Feb 21, 2017 19:07:23 GMT -5
youtu.be/fO6BVAF0o_4This was on my way home. Taped my new s7 to the headlight real quick with duct tape. Vid isn't great quality but this is the best I could do at the time. It's running like a top at the moment. Max speed was 64 in vid. If you turn your phone sideways video is better
