Post by thxcuz on Sept 21, 2016 12:37:35 GMT -5
IT IS ALIVE!!!!!!!!!
slow, but ALIVE!!!!!
Post by thxcuz on Sept 22, 2016 11:56:42 GMT -5
as I stated it's slooooow. It takes off fine but i can't seem to get it over 18mph maybe 20 after a long stretch. were these restricted back in '08? My tao tao wasn't restricted. Some 2 strokes were but I heard the 4 strokes aren't, but I could be wrong. maybe I just need to tune the carb. Idunno. I will say this much, the engine is smoother and quieter than my old engine
Post by Deleted on Sept 22, 2016 13:19:21 GMT -5
I am running an 08 and I have no restrictions that I know of. I just hit 40 mph on the gps 2 days ago. Get the carb. as tuned as you can and be sure to upjet if you modify the intake or exhaust...then tune the variator and make sure the belt is the right size and in good shape. Check your valve lash and set that dead on before you tune the carb. I would also change the oil run it a bit, and then change it again as it is so cheap to do and who knows when it has been done prior to you owning it?
That's all I can think of at the moment...other guys here can help you more I think. Nice job on the engine swap. I, thankfully, have never had to do that...yet.
Bill
Post by thxcuz on Sept 22, 2016 21:41:13 GMT -5
I have a pod filter on it now but I wonder if the stock air box will help. I think I have a 79 jet in there now. Could I be lean? Would that mess with my power? I have an 81 jet from when I had my bbk but I think that would be too rich. I'll check the valves tomorrow
Post by Deleted on Sept 22, 2016 22:18:17 GMT -5
I have a pod filter on it now but I wonder if the stock air box will help. I think I have a 79 jet in there now. Could I be lean? Would that mess with my power? I have an 81 jet from when I had my bbk but I think that would be too rich. I'll check the valves tomorrow I am running an 85 jet with my pod filter and it is working very well. Stock 49cc engine. Bill
Post by Deleted on Sept 23, 2016 8:50:50 GMT -5
I run a pod on a 20mm with a 90, tried a stock air box for giggles, ran like crap, couldn't get the carburetor set right, really think it was too restrictive for my setup at that point.
Post by Deleted on Sept 23, 2016 11:46:45 GMT -5
I love stock airbox. Easy to tune. I had 50mm cyl and 47mm org head (16,5mm org carb, #85 mainjet). Worked like a dream (Variator was org).
Post by thxcuz on Sept 23, 2016 11:50:28 GMT -5
I took off my carb and there is gas inside my float. I wonder if that's the problem.
Post by acvw74 on Sept 23, 2016 12:58:42 GMT -5
I took off my carb and there is gas inside my float. I wonder if that's the problem. Probably not helping...
Post by humanshield on Sept 23, 2016 13:32:50 GMT -5
Yes, that is definitely a problem. The floats don't float fully if there's any gas in them. That will make the floats sag lower, the fuel level will then be too high causing a rich mixture.
That could be why your top speed is so slow. One possibility.
Post by Deleted on Sept 23, 2016 13:38:01 GMT -5
I took off my carb and there is gas inside my float. I wonder if that's the problem. Gas inside the float will, of course, keep it from floating. It if can't float, it can't shut off the flow of gas to the carb. when that flow is not needed..idle, going slow, starting...etc. Probably a pinhole in it somewhere which might be able to be repaired, or, a new float can't be too much I wouldn't think or, do like I did, about a year ago I bought a new carb that came with an 85 jet installed and an extra 90 jet and a larger primary jet all for like $25 shipped! Bill
Post by thxcuz on Sept 23, 2016 14:00:35 GMT -5
I have some spare carbs. I just use the floats from that
Post by Deleted on Sept 23, 2016 23:16:48 GMT -5
heh, I remember my dad soldering pinholes in brass floats...
Post by Deleted on Sept 23, 2016 23:21:47 GMT -5
heh, I remember my dad soldering pinholes in brass floats... Yes, that would seal them up properly. I think our floats now in these scoots are plastic, and, you could seal them but, I would not mess with it and just get a new carb. If it is old enough that the plastic float is sinking, or, if it was new and so poorly made it was doing this, then I want a new one for $25.00. Bill
Post by thxcuz on Sept 24, 2016 18:17:14 GMT -5
Newer carb but, you know....still chineese. The carb on my donor bike is possibly from a kymco. It's logo is on it. But a carb is a carb isn't it?
