Post by Zino on Jul 26, 2020 8:30:24 GMT -5
The slow rolling to 10 mph suggests Stiffer clutch springs may be the fix . Is your top end still the same ?
Post by geoffh on Jul 26, 2020 15:01:19 GMT -5
Thanks zino maybe they have just given up,I will shop around the springs are smaller on this old dog than my 04 CS50,and yes top end just the same.
Post by aeroxbud on Jul 26, 2020 16:26:26 GMT -5
When did you last check the rollers? If they are a bit flat it might do this.
Post by geoffh on Jul 27, 2020 14:35:36 GMT -5
Thanks aeroxbud,I am going to inspect the whole CVT next,sadly I have 4tonnes of garden supplies due on Friday so the scoot will have to sit it out.
Post by geoffh on Aug 26, 2020 14:14:00 GMT -5
I may have the bug bad,I found these on EBay UK with the seller only willing to ship within the UK,I have the only CG50 currently road legal in the UK so his market was really small Yamaha part number 2JA-27476-50 is the right hand 2JA-27475-50 is the left hand I am willing to pass these along at cost plus the shipping,PM me if need them. Geoff
Post by geoffh on Apr 29, 2021 14:52:49 GMT -5
Grandads still waiting for some TLC just going to move this up the thread list for another addict.
Post by yambw’s on Apr 29, 2021 14:58:23 GMT -5
Love it!
Post by geoffh on Jul 3, 2021 8:53:39 GMT -5
Well it,s been a while,grandad has had almost a year "resting" in the garage so it,s time to blow the dust off and get him rocking, I stole his coil for the commuter build so with that replaced and a tadge of easy start he fired up easy enough,some blue smoke but that will burn off. Next up will be the MOT test and then road tax then we are good to go. Geoff
Post by geoffh on Jul 16, 2021 15:41:28 GMT -5
Rocking grandads up and rockin all ready to go,starts first kick,not sure about the slow roll start we have,nt got that far the headlamp and tail light are not working,the bulbs are fine so it,s a switch or connection I have to chase down!! The manual asks me to check the lighting resistor?? Is that the white 2 1/2 inch by 3/8 block of porcalainey stuff near the horn (picture refuses to load).anybody know??
Post by aeroxbud on Jul 16, 2021 18:52:40 GMT -5
Check the actual voltage and earth wires with the bulbs out. I was chasing my tail for a day on the slider. Turns out although the bulbs looked fine. It was shorting to earth from inside the bulb. Once I removed the bulb, all the checks came up good. Before that, nothing. The bulb holders, especially the headlight metal prongs can bend back not making good contact too. Good luck.
Post by geoffh on Jul 17, 2021 8:32:19 GMT -5
Lights back on and functioning,I couldn't,t find the fault so I stole a live from the ignition / on side and have lights on without the engine running not ideal but I can live with it.had to cancel the MOT appointment but they were nice about it. I will see what Monday brings work wise and hopefully use the truck to transport grandad to and from the MOT station.
Post by milly on Jul 22, 2021 14:28:55 GMT -5
Yes the white porcelain thingy will be the resistor Geoff
Post by geoffh on Jul 22, 2021 15:02:49 GMT -5
Thanks Milly,I had spare old one on hand swapped it out it made no difference I may have two defunct resistors,I rigged the lights to work,just got to sneak it past the MOT guy on Saturday.
Post by jloi on Jul 23, 2021 7:30:49 GMT -5
" just got to sneak it past the MOT guy on Saturday." good luck.
Post by geoffh on Aug 3, 2021 8:52:27 GMT -5
So I put the rear brake/tail bulb in wrong and fried the stop switch . I,m on staycation so it,s not a show stopper but it,s taken a while to source,but worth noting there is an old type and a later switch,the later switch is predominant on flea bay so be careful if you need to buy one.part numbers/picture and vendor when it arrives. Geoff
