Post by benji on May 17, 2018 18:30:08 GMT -5
Ok, cleaned the carb. Nothin.
Pulled the plug and swapped it. Nothin.
Replaced the coil. Nothing. Checked spark, and the spark looks quite weak. How do ya fix that?
Post by benji on May 17, 2018 18:30:57 GMT -5
Please don't say ecu or I'm giving it away like spaz haha
Post by Happypancake! on May 17, 2018 18:43:00 GMT -5
new fuel pump ?
Post by AtariGuy on May 17, 2018 19:42:40 GMT -5
If you give it away, i'll road trip to washington and nab it up lol
Post by benji on May 18, 2018 12:27:21 GMT -5
Got a new pump. It's getting gas and the plug is wet. Stumbles and does when I start it.
Post by benji on May 18, 2018 12:27:51 GMT -5
Can't be the valves yet... Can it? Things only got 450 miles
Post by pitobread on May 18, 2018 12:42:16 GMT -5
Jumped cam timing? Compression/leakdown test?
Post by Lucass2T on May 19, 2018 4:41:33 GMT -5
Did you do a full tune up? Adjust valves, new plug, check ground wires are connected properly. Does the fuel pump prime? Is there a way to check ignition timing? It might be off. It's not fuel injected is it?
Post by Happypancake! on May 19, 2018 6:43:12 GMT -5
Video of it trying to start?
Post by benji on May 19, 2018 12:53:31 GMT -5
I'll do one later today. I'll actually start sometimes, but barely idle and eventually die. Dies if I give it throttle at all. Looks like weak spark.
Post by benji on May 19, 2018 12:57:09 GMT -5
Did you do a full tune up? Adjust valves, new plug, check ground wires are connected properly. Does the fuel pump prime? Is there a way to check ignition timing? It might be off. It's not fuel injected is it? I did check the pump. That's really about it haha. I checked spark and it looked weak, but I dunno. I'm losing energy on this one.
Post by 'O'Verse on May 19, 2018 13:57:03 GMT -5
Post by Happypancake! on May 19, 2018 14:13:32 GMT -5
I don't think the spark has anything to do with it. Something simple like weak battery, air leak. Make sure the pilot jet screw is only turned out 1-1/2 turns.
Post by benji on May 19, 2018 15:00:15 GMT -5
or strip it and put it on eBay...
Post by benji on May 19, 2018 15:01:12 GMT -5
I don't think the spark has anything to do with it. Something simple like weak battery, air leak. Make sure the pilot jet screw is only turned out 1-1/2 turns. a weak battery will keep it from idling? I'm keeping the battery on the charger and it seems to be getting 12 volts pretty well.
