Post by pitobread on May 25, 2018 22:56:38 GMT -5
Did some work for someone in exchange for a bunch of Piaggio Derbi's and ..... Piaggio/Gilera typhoon.... This space reserved for future shennanigans.
Post by drc174 on May 25, 2018 22:59:41 GMT -5
Oh hell yeah! I got plastics n stuff if you need something. I still have my frame and all
Post by pitobread on May 25, 2018 23:03:24 GMT -5
It appears all the plastics are there, as is the original engine and some aftermarket pipes and a Malossi CDI and coil, Malossi Clutch and probably some other surprises.
My initial plan is to put the Derbi 12" wheels on it, and possibly try and trade RC-One cases with someone and make another monster.
But I honestly don't know what I am going to do yet.
The forks are awful on it, they are leaking and the bushings are shot.
Post by drc174 on May 25, 2018 23:41:41 GMT -5
It appears all the plastics are there, as is the original engine and some aftermarket pipes and a Malossi CDI and coil, Malossi Clutch and probably some other surprises. My initial plan is to put the Derbi 12" wheels on it, and possibly try and trade RC-One cases with someone and make another monster. But I honestly don't know what I am going to do yet. The forks are awful on it, they are leaking and the bushings are shot. Gotta shell out the 750$ for the Malossi forks. You will not want anything else after it. Mine have been on 4 builds. (kinda made it worth the money)
Post by Lucass2T on May 26, 2018 1:25:52 GMT -5
You found some proper good scoots right there! I really like the typhoon, or NRG? Is it ac or lc?
Post by pitobread on May 26, 2018 7:44:12 GMT -5
It is AC, North America only got them in AC.
The Derbis are meh, just Atlantis AC as well, but they are big body wise. We did get Atlantis LC here but they are pretty rare.
Post by pitobread on May 26, 2018 13:18:54 GMT -5
Thrown together with Derbi wheels. Looks good with the "Narrow" 12" wheels. Have to find bearings for the front wheel, and need to swap the caliper out for the Derbi AJP as it has a bigger rotor.
Post by Lucass2T on May 26, 2018 14:28:18 GMT -5
Those are exactly like Gilera Runner wheels
Post by 'O'Verse on May 26, 2018 20:59:19 GMT -5
Thrown together with Derbi wheels. Looks good with the "Narrow" 12" wheels. Have to find bearings for the front wheel, and need to swap the caliper out for the Derbi AJP as it has a bigger rotor. Frame looks just like a Zip frame. But without the single sided front suspension. I always wanted a typhoon. The body just looks so mean from the side. Nice bargain! Too bad your RC-one cases are the Minarelli version. If it's not to late try to trade the cases for the Piaggio version. Bolt right in monster. Edit: I forgot your a machinist. Just make a piaggio/minarelli mount for it. Bam! Color scheme is already there.
Post by pitobread on May 27, 2018 10:17:05 GMT -5
I think it's bigger than a Zip.. Although I may try and get 10" zip wheels and try to lower it slightly to make it more "Zip" sized.
I think I want to do a NRG or Gilera Typhoon LC front... Just have no idea where to source one.. Need the front panel, the rad and the lights.
but for now I am just leaving it in the back of the garage and hoarding parts.
Post by drc174 on May 27, 2018 15:53:07 GMT -5
I have put 10” zip wheels on a drag typhoon I built a 8 years ago. The wheels are way to narrow for that fork. It just won’t work well.
Post by pitobread on May 27, 2018 16:20:14 GMT -5
i wonder if I put a non SP front zip fork on it?
Post by drc174 on May 27, 2018 18:24:19 GMT -5
Stem too short, there will have to be some work done
Post by pitobread on Jun 5, 2018 22:54:09 GMT -5
Got bored. 3.0 x10 slick stretched on the wide typhoon wheels. Probably going to be on 10"... I just can't get used to the 12" It also makes it shorter and more zip like. Did I mention I really want a Zip? Still need to find a euro headlight..
Post by pitobread on Jun 5, 2018 22:54:48 GMT -5
Oh, and I ordered Malossi RS24 rear shock and forks for this bad boyyyee.
