Post by repherence2 on Oct 21, 2018 18:22:33 GMT -5
Carb that was on the scoot. OKO 28, k48 pilot 125 main. Polini short bell mouth.
carb with bell mouth and tea strainer mesh installed.
carb with aluminum splitter plate installed. viewed from mouth end of carb.
carb mouth with aluminum splitter plate installed.
carb with bell mouth, tea mesh, splitter plate and CT intake manifold.
Taida radiator for future set up.
speedo gage face. modified to hold Trail Tech tachometer and cylinder head temp gages.
gages mounted and back spaced with nylon spacers so that the illumination light for the speedo cluster illuminates the temp and tach gage at night.
speedo housing modifications to accommodate the back mounted Trail Tech gages.
speedo cover. tested the toothpaste fix on half of it. 8 cycles of toothpaste buffing with Crest.
stripping it down.
wires...
deconstruction.
power plant.
Post by repherence2 on Oct 21, 2018 18:29:33 GMT -5
Post by repherence2 on Oct 21, 2018 18:59:11 GMT -5
Michelin S1 3.00 10 rusted YMS v8 sectional pipe. pink cooling fan air scoop. bought the block as a 83cc cast iron bore, 50mm piston, jog 90 CVT internals. made this shock bracket out of aluminum bar 1/8" thick 1 1/2" wide. front end in need of over haul.
Post by 190mech on Oct 21, 2018 19:21:14 GMT -5
Cool build!Looks like youve got a touch of corrosion here and there,perhaps thats the theme of this ride..Keep us posted!!
Post by repherence2 on Oct 21, 2018 19:31:47 GMT -5
Cool build!Looks like youve got a touch of corrosion here and there,perhaps thats the theme of this ride..Keep us posted!! It's been sitting on the side of the house since January pretty much. I took it for a spin several months ago. Tried running a yasuni c30 on it but it couldn't rev up high enough to pull hard. I live about 200 yards from Kailua beach and 2 years ago I lived 200 yards from Waimanalo beach. I have neglected this thing for years. The salt spray from the ocean corrodes everything... but Hawaii is a nice place for riding scoots. I'm tearing it down to remove rust, fix some wiring, repaint the frame. I'm going to try removing rust from some steel parts using electrolysis. (Oxyclean, water, plastic bin and a battery charger).
Post by Lucass2T on Oct 22, 2018 3:37:18 GMT -5
What kinda or brand disk rotor is on there.
Post by oldgeek on Oct 22, 2018 16:51:21 GMT -5
Finally! I see a scoot with more rust than mine. I am just over a mile from the beach.
Pretty slick adding gauges to the cluster!
Post by repherence2 on Oct 22, 2018 20:21:18 GMT -5
I will verify rotor brand when I get home from work.
--checked-- NHRC is the brand name. it is also etched "YAMAHA JOG. FLOATING ROTOR". I am pretty sure it is 200mm.
Post by repherence2 on Oct 22, 2018 20:36:20 GMT -5
Finally! I see a scoot with more rust than mine. I am just over a mile from the beach. Pretty slick adding gauges to the cluster! I have been on the windward side of Oahu for the last 6 years. All the salt spray from the ocean gets blown inland. It corrodes steel and aluminum. If the bike sits for a long time, the aluminum oxidizes and it gets covered with white aluminum oxide powder. It's an endless battle. In regards to the gages, originally I had the temp gage mounted externally on the headset/speedo bezel. It was exposed to the elements, and it would have been easy for someone to rip it right off the bezel. I couldn't read the gage at night too. So I decided to place it in the speedo cluster to protect it from the weather and people, as well as have the gages readable at night via speedo illumination lamp.
Post by Lucass2T on Oct 23, 2018 0:59:57 GMT -5
--checked-- NHRC is the brand name. it is also etched "YAMAHA JOG. FLOATING ROTOR". I am pretty sure it is 200mm. Thanks!!!
Post by 808ministroke on Oct 23, 2018 4:56:06 GMT -5
I live on Oahu currently riding a gtx also mine doesn’t have panels either except front panel. It’s a blast raking off red lights in a piece of shit looking fucka and smoke em. Nice build so far. I I have another build similar in that I cut the case to mold a 50 mm piston still working on that one though good luck shoots
Post by islandscrub on Oct 23, 2018 17:41:29 GMT -5
That's a healthy patina you got on there, I'd get on that asap. BTW I recommend TC-11 as a lube/protectant, been using the stuff for years, it disappeared for a while, and now its back on shelves. I use it on all my tools and locks and stuff and they never get rusty. Works good on all the bike joints and whatnot. Can by it at pop marine by Nicos pier 38.
Post by repherence2 on Oct 23, 2018 20:27:01 GMT -5
That's a healthy patina you got on there, I'd get on that asap. Lol! I like that one, "healthy patina". Thanks for the TC-11 recommendation and where to find it, I appreciate it. I was beginning to think of what I could put on the steel parts for preservation...and then you provided a solution. I didn't want to fully get into the surface rust issue without a plan for preservation. I think I'm going to initially try Naval Jelly to get rid of the rust. I was going to wire wheel and sand it, but I don't want to deal with airborne rust dust.
Post by 190mech on Oct 23, 2018 20:42:30 GMT -5
The pipe looks very crusty,,hope it'll clean up without breaking through...
Post by repherence2 on Oct 23, 2018 20:53:08 GMT -5
I live on Oahu currently riding a gtx also mine doesn’t have panels either except front panel. It’s a blast raking off red lights in a piece of shit looking fucka and smoke em. Nice build so far. I I have another build similar in that I cut the case to mold a 50 mm piston still working on that one though good luck shoots 808ministroke, it's actually in tear down phase for overhaul. I put the 90 block in because I pulled the threads out of a stud hole while torquing head studs on my original gtx block about 4 years ago. It used to be my daily rider from Waimanalo to Pearl Harbor everyday. I used to run it with full panels. About 2 years ago, I took the rear panels off because it was cracked where the gas cap is. I left the front fairings on at that time though. I guess I was going for that same unassuming look...all busted up piece of crap, just all motor no fancy. Nice scoots get targeted by thieves. The engine that is on it currently could make the speedo needle go off-scale past the high beam indicator and pin against the clear speedo cover. If you look at the pic of my speedo face you can see 2 black dots past the 50. It was to give me an idea of the speed once the needle went off-scale past the 50 mark. First dot is "60" and the second dot is "70". I am in no way claiming 70mph. The speedo was calibrated to the radar speed sign at the start of Waimanalo up to 45mph. The only proof of speed I have is a speeding ticket for 49mph in a 35mph zone in Hawaii Kai.
