Post by ThomasTPFL on Mar 9, 2019 22:54:35 GMT -5
I have 2 predictions; 1: the belt will probably be the 764mm or longer. 2: the belt will be so long it will take some tuning to make it sit right in the OEM vario. Have you tried going wider? Wouldn't wider be even longer still?
Post by ryan_ott on Mar 9, 2019 23:09:43 GMT -5
I missed the wider part...
Wider is easy to deal with on the variator with shims. Outback on the TD you can go wider to a certain amount but too wide and you’ll be opening the pulley, changing the ratio. So you can go a few mm wider but not much more then the TD is designed for. Up to 2mm you may be ok. But it’ll still be longer.
I have tried belts on hand here from 16.5-18 and didn’t notice much difference.
Post by benji on Mar 9, 2019 23:45:58 GMT -5
I would think if the TD is bigger then the belt would need to be a hair wider (and of course longer) and the vario shimmed to match. But ya, not much tho. Maybe 0.5 or 1 mm with a more aggressive angle.
Post by ryan_ott on Mar 10, 2019 0:18:52 GMT -5
Post by Lucass2T on Mar 10, 2019 4:17:47 GMT -5
I have the tp 122mm pulley on the axis. Had the athena belt first and that one wasn't long enough make use of the full 122mm. Now i have a stage 6 overrange (for minarelli short case) belt on there and thats just perfect! I have some pics somewhere i think in my build thread.
Post by Lucass2T on Mar 10, 2019 7:48:04 GMT -5
 Did quite some research on belt lenghts studying multiple sources to determine the right mesurements belong to certain belts. Took a gamble on the s6 belt thinking it would be too long...wel decide for yourself...
Post by benji on Mar 10, 2019 9:42:51 GMT -5
I have the tp 122mm pulley on the axis. i have a stage 6 overrange (for minarelli short case) belt on there and thats just perfect! w=17.2 / h=8.2 / l=806; 30deg Drive belt Stage6 R/T Oversize Minarelli Short Model: S6-5916628 Those numbers seem like they jive. I would've thought 806 would be a hair too long; I bet the angle allows it to sit deeper and 'shorten' the belt in the pulleys. Did you have to shim the vario?
Post by ryan_ott on Mar 10, 2019 9:59:54 GMT -5
Is the axis the same shaft to shaft length as the Zuma... I got about 257mm
Post by Lucass2T on Mar 10, 2019 10:22:21 GMT -5
I have the tp 122mm pulley on the axis. i have a stage 6 overrange (for minarelli short case) belt on there and thats just perfect! Did you have to shim the vario? Yeah a little, maybe 1mm. Without shims its def too loose. ryan_ott. Dunno. Never measured.
Post by benji on Mar 10, 2019 10:24:59 GMT -5
Is the axis the same shaft to shaft length as the Zuma... I got about 257mm I'm not sure, but I think the axis is really close to the Zuma motor. I want to say it's basically an aerox motor with a drum brake in the rear instead of a disc.
Post by Lucass2T on Mar 10, 2019 10:26:00 GMT -5
Is the axis the same shaft to shaft length as the Zuma... I got about 257mm I'm not sure, but I think the axis is really close to the Zuma motor. I want to say it's basically an aerox motor with a drum brake in the rear instead of a disc. Axis = minarelli shortcase. Shortcase belts are longer than longcase belts. Strange but true.
Post by harleyracer59 on Mar 10, 2019 10:35:16 GMT -5
that looks like you found a winner!
Post by ryan_ott on Mar 10, 2019 14:06:46 GMT -5
The Zuma is considered a long case. 806mm will not work. I tried the longer belts I have on hand that I thought would be too long and never tried before. 788mm - way too long, 792mm Mitsuboshi (actually 774mm) very good fit but slightly too short, Malossi 6111294 - 779mm slightly too long as it rides just over the edges but usable. I think the true length should be 776mm. Now to find that belt...
Post by ryan_ott on Mar 10, 2019 14:29:31 GMT -5
Post by benji on Mar 10, 2019 15:34:20 GMT -5
I'm not sure, but I think the axis is really close to the Zuma motor. I want to say it's basically an aerox motor with a drum brake in the rear instead of a disc. Axis = minarelli shortcase. Shortcase belts are longer than longcase belts. Strange but true. yeah, I thought that Was kind of long for a long case. The axis is a short case? Damn. What about the grand axis? Is that a long case?
