Post by krisgenchev on Apr 12, 2020 0:17:42 GMT -5
If you don't mind me asking where did you order the stuff from? I might be interested into getting this "kit"? Thanks.
Post by Zino on Apr 12, 2020 7:50:15 GMT -5
dynoscooter.com is where I got the polini belt ,malossi shim kit and top performance torque driver .
Post by krisgenchev on Apr 12, 2020 12:28:07 GMT -5
dynoscooter.com is where I got the polini belt ,malossi shim kit and top performance torque driver . Thanks, never knew of this place, prices are pretty good! Edit: It said 7 days , custom order ? Was it the same with you, and how long did you waited for it? Thanks.
Post by Zino on Apr 12, 2020 15:45:30 GMT -5
I believe they drop ship some stuff from other vendors. I chatted through email with them to verify a few thing My stuff came within a week .
They ship out of the Massachusetts . I have bought from them a couple times in the fall and winter. The Covid thing might be slowing them down.
Post by krisgenchev on Apr 25, 2020 0:19:47 GMT -5
I've got mine last week, but my dumb a** forgot to order the spacer, i just got it and will be installing soon, what kind of torque spring are you guys using with this pulley, i was running Malossi white and was happy with it, was thinking to try a little stiffer .. the yellow that came with it should it be equal to the white Malossi one? Thanks .
Post by Zino on Apr 25, 2020 0:28:03 GMT -5
I kept the same spring as before a malossi white . I did have to shim different about a half mm with the malossi variator is what worked best.
Post by krisgenchev on Apr 25, 2020 0:44:44 GMT -5
I do have the multivar as well, mine is F12 cases don't know if they are different then zuma cases... Originally the Multivar 2000 comes with a little spacer which for some reason you have to put before the variator only on F12 NO CLUE WHY .. it says it in their manual, but i think the F12 cases in US are just like normal Minarelli and there is no need of that , i just mocked up everything it seemed to like this spacer after the variator basically shim and the belt was all the way out on the pulley, tomorrow or Sunday i will put the shim on the back and see how is everything sitting..
EDIT: The malossi spring is way TALLER than the little shorty that the TOP PF came with.
Post by krisgenchev on Apr 25, 2020 0:49:42 GMT -5
Post by ryan_ott on Apr 25, 2020 22:59:04 GMT -5
I found the supplied short yellow spring waayyy too soft for my liking. I usually use malossi yellow. Red nowadays..
Post by matlock on Jun 20, 2020 23:18:42 GMT -5
i wonder how this will work on my adly rt 50 short case minarelli i hope i can do the same my question is if that is the budget kit what is the quality name brand kit that will fit and is the same thing? malossi overange torque driver the same size which one would i need?
Post by Zino on Jun 21, 2020 6:55:04 GMT -5
The only part that is a budget is that you already have a good clutch and variator and you are not replacing them
The malossi overrange stuff is really nice and is designed to work together . It does require you to open your case up a little bit with a dremel so it will spin freely. The malossi overrange torque driver is 128 mm the trophy is 122 mm and stock is 115 mm .
Post by matlock on Jun 21, 2020 10:47:29 GMT -5
how would i go about installing that do you have a link for the one i would need from scooterpartsco if they have it and the belt i would need ....basically its not hard to do by opening case you mean slight cutting around the edges? i would get a better takeoff and still have same top speed and better accelration all the way through?
Post by Mech Warrior on Jul 14, 2020 2:05:53 GMT -5
Often times different brand belt manufacturers measure their'e belts differently so it's not always a direct one size fits all situation.
Post by Lucass2T on Jul 14, 2020 9:31:45 GMT -5
I’m thinking of picking up a Top Performance 122mm rear TD, being a larger OD it will need a larger belt to take advantage of its benefits. A stock Zuma belt is 738mm, I’m thinking something in the 750mm range would work well. I just checked the belts I have on hand Polini 248.003, Polini 248.040, Athena 751mm long and OEM Zuma. All are from 738-741mm. Not the 750ish all but OEM are supposed to be. Has anyone found a good belt to use with this pulley or are there belts in the 750’s that are actually their stated size?  Just noticed this thread. I have the same TD on my axis. 49ccscoot.proboards.com/thread/8764/70mph-daily-driver-end-storyquote myself, page 27, 2nd post
Post by 65grendel on May 15, 2022 16:05:58 GMT -5
Does this “budget overrange “ let you keep the starter functional? Either way I’m glad I’ve found this thanks for doing the legwork.👍🏼
